Tom or TA -
Do you estimate a drop / significant drop in measurements of lumens and throw due to changing from 14awg wires in the prototype Tom is testing to the production unit? It makes me wonder why they would go with such a THICK wire thickness in the prototype and change it for production. i understand the reflector clearance aspect, but seems like an important change considering output and resistance? Maybe i’m wrong? I just know i’m never going to be changing my driver wires to increase output lol…
That would be great! If I order the WT90, I’ll most likely get it with batteries (assuming the batteries can be shipped to my country… without too much added shipping fee)
Not that much of a difference. It arrived with some smaller wires when I first got it and I am the one that installed the 14AWG in it to see the best case scenario as they were having clearance issues and wondering the best option for the wires in a production line setup.
Fitting that 14awg was a big hassle and no way it could be done on a production line, took me like 45 mins of tweaking to get it installed and not shorting out.
That said even with the single thinner wires it came with, I surprisingly only saw minor gains with the swap, something like 5% on my tube. So 2 of the wires they had in it (they didn’t say the size) should close that gap even more.
Overall I don’t see it being a big issue in output on a stock light. Based on that testing.
Thank you for the info TA. Good to know, I just didn’t want to have to start thinking about potentially considering swapping driver wires out, i probably wouldn’t of anyway if I’m being honest.
When is somebody gonna hurry up and take my money for this already???
Does anybody know if people be offered one of these in the order of their post here or will it be offered generally again and then it’ll be first come first serve?
I NEED to make sure I’m one of the ones that’s in for one of these!!!
Think I have only a pair of P42A's, should get more. They have the initial dip compared to a 40T so don't look good for 0-30 sec tests, but slighter better then the 40T for the full period of drain, and of course slightly higher capacity.
Looking at the specs from HKJ's reviews, the cycle life looks way better:
P42A: Cycle life: 500 cycles at 4.2A charge and 10A discharge for 80%
40T: Cycle life: 250 cycles to 60% at 6A charge and 35A discharge
Charge rates are different, but still... Hhhmmmm. Those high charge rates we don't do, so I'm not even sure this info is relevant.
I was only teasing, lol. ;-) But WildTrail has got more in the oven already, so don’t put that extra battery too far away. :-) Last but not least, I agree the P42A on NKON was an offer too good to let pass. I just figured I didn’t buy enough for a triple battery light. :FACEPALM:
By the way, Jacky gave me some explanations concerning the battery carrier and the two LEDs in the center part that indicate the charging/discharging status. I will soon post some more information here, maybe including some first hand videos for illustration. He is now checking cut-off voltage when discharging via USB-C. I was also very pleased to hear that WT90 will work with smart chargers, i.e. type C to type C cables.
TA, I guess I will keep you busy posting another new link for the updated manual, lol. :-P Anyway, it will hopefully be the last update, so the print job can commence by the end of this week.
Is it just me or are those two comp’s impossible to decifer? P42a tested at 10amp discharge and 40t tested at a 35 amp discharge??
Anyway, I have quite a few p42a’s, identical performance to 40t, guaranteed fresh cells if buying from authorized dealers, and in 2021 at least half the price as a 40t. Mooch has some good relevant info on how they measure up (and surpass technically) the 40t, except for that first 30 seconds like you said.
Oh man, now I’m gonna have to go back and count how many requested a silver one before me. I requested mine on the 150th post so I gotta read all 149 before me and see if I made the cut.
Riiiight, there are new posts on this everyday and I can’t take it!!! I need the peace and comfort of knowing it’s been ordered already so I can go on with my life.
I just counted and there are about 21-22 silver requests before me so if there are 25 exactly like we’re told…I should be in for a silver of the first batch. HELL!!! YEAH!!!
I guess I will be incessantly looking for my invite to buy that bad boy everyday until it happens.
