Thanks for the great photos Noir!
And it confirms what I said before
Great!!!
yep, the DQG Slim AA is indeed a bit longer. I have measured mine at 76,6 mm, 2,1 mm longer than the FWAA. The DQG Tiny AA II (which is of course a twisty) is 68 mm long, 6,5 mm shorter than the FWAA.
Interested in one
Can I have the code please? Many thanks
Interested. Please send the code. Thank you!
I can’t believe it’s that much smaller than the reylight Pineapple… dammit, maybe I will have to order one of these. But I’ll probably just wait for brass to come out, if it ever does. Because it really should - freeme
Arrived today. This is my second Lumintop, and this one is even more impressive with the Anduril 2 driver. Soooo small. I haven’t got my head around the interface yet, but I will.
Thanks for this. I am very pleased.
Ain’t no lie this little puppy gets scorching hot in short order (Vapcell H10). 10-15 seconds on turbo will curl your hair.
it sure does! I’ll keep mine in simple UI with a greatly reduced top ramp - no turbo. I can always put it back in advanced UI if I want to show off for 5 seconds.
Mine is in the US, but they can’t seem to hand it off to USPS.
I would really like to see a stainless bezel for this light, I use one on every EDC… lets face it they get dropped.
Assisted from that, I am excitedly waiting for it!
Ordered with the 219c 4000k. Thannks Freeme!
FWAA deal will expire
on May 10, 2021 Monday @23:59 (GMT+8)
Any word if Lumintop will make a Titanium or Titanium-copper version of the FWAA?
Anyone know how the tints compare for the Nichia 219C 3000K and 4000K versions?
Any projection of CRI on these two and for the SST-20 4000K?
Apologies in advance if this was covered earlier in this thread.
FREEME, PM code please and thank you!
Nichia 219C 3K, 4K and SST-20 4K are 90 CRI,
Nichia 219C 5K is only 70 CRI.
Since this is a FET +1 driver, this should help the tint issues normally associated with the SST20, but I’m really curious about the two 90CRI Nichia’s. Can anyone with those comment on the green/pink tint of these options?
I’ve got Nichia 3k and 5k. Both floody and 5k is not bad bad for low cri but beeing called Nichia AND not High CRI botherd me so i swapped with Osram’s.
I still have a mixed feelings about 3000K, seems to me a bit yellowish/greenish... Need to compare with other light i have (but i need to find that one first)
Lumintop’s current 4000k sst-20s are bloody gorgeous, even on lower power modes.
Interested - Could you send me the Code please?
Thank You
Is it me or does the FWAA have a diffrent version of Anduril2 then the UI chart?
With 3C i get battery check, then beacon, then temp check , then battery check again. (NO SOS)
can someone please confirm this
I did mention in my video. Might require modification of code to enable?
Is it me or does the FWAA have a diffrent version of Anduril2 then the UI chart? With 3C i get battery check, then beacon, then temp check , then battery check again. (NO SOS) can someone please confirm this
