Thanks for the input! I actually pulled up the review for the older black Shockli cells I have, and it looks like they perform well up to about 5 amps - this might actually be a good balance of runtime and brightness then, assuming the FET will pull 5 amps? How does the FET regulate how much current its pulling i.e. how does it “know” the max current to pull from a cell, say 3-5A for mine, vs 10A for a 10A cell? I think I’ll order one and try it out
The FET does not know. It is a relationship of cell, circuit path and led resistances that determines the Amp draw. The lower the path resistance, the more current will flow. Take a look at Ohms law.
I’m familiar with ohms law and use it when building vape coils, but I believe the FET is playing some role in regulating the amp draw, or at least limiting it. If the amp draw was only dictated by the LED resistance and battery voltage, like a mechanical vape mod, then you’d have low-amp-rated batteries venting and exploding in flashlights often, and I don’t think this ever happens with enthusiast lights? As well, since FET lights produce higher lumens with higher amp-rated batteries, there’s got to be something else at play here? If a FET light is trying to draw 15 amps from a 3A cell, the battery would likely vent if not for the heat of the light triggering thermal stepdown - maybe its the thermal stepdown that acts as a safeguard?
Got mine about a week and a half ago and I love it so far. Neal shipped it quickly, about 12 days from placing the order to the central US, and about half of that time it was in USPS possession - they took forever to move it the rest of the way to me.
I need to clean the board and optics but the emitters and soldering/wires look fine...lots of flux residue and some dust, though. The color on mine is a little disappointing being on the blue side of grey and a different feel/texture than the first FW3A batch. Switch feels pretty decent really, tactile but a bit mushy on the edges. I can't seem to make it catch or do anything weird, which I'm glad about after all of the switch button woes the last couple years. The H10 cells are definitely better in this light than the gold 1000mAh. Clip is pretty well formed and finished and I really like the cigar ring - cigar ring is going to stay on the light (I wish it were black in color, something besides bright white). SST 4000K is very nice at all levels although a tad warmer than I usually like. After seeing pics of the 219C 5000K I might order one of those also. I don't think that I dislike Anduril 2 - still getting used to the changes and missed the development thread - but I think I like the original a little better. Once I realized the division between the shipped-as Simple mode and the Advanced mode, I started to warm up to it more. Be careful with the skinny little o-ring on the command tube if you remove it. I sliced a thin sliver from mine when reinserting it before smearing a little grease there - easy to fail to seat the tube all the way if you aren't aware. I hope they bring out the turbo glow gasket for this one.
All in all I'm really pleased with this so far. Burned a napkin at work...coworker ordered one immediately. I hesitated to order this because although I really appreciate the collaboration that we've had with Lumintop, I seem to get a high failure rate with them and the QC and other issues of late have made me feel like I'm taking a higher calculated risk when I get one of their lights now. Currently awaiting the outcome of their convoluted warranty/communication on a driver-dead ODL20C purchased from Banggood, and it's looking like I may end up holding the short end of the stick on this one. But the FW3A has been fantastic and I hope this FWAA follows suit over time.
Thermal regulation is acting WAY too late, regardless how low the threshold is set. I set e.g. 45°C for stepdown but on turbo mode it’s getting beyond 70°C before actually stepping down. Thermal sensor was calibrated properly, of course.
If the flashlight gets warm (> 40°C surface temperature) there’s no way of getting back from Turbo. 2 clicks do nothing, I can only turn off. As long as the flashlight is still handwarm or cold, there’s no problem cycling between Turbo and Ceiling.
I dont think u can ? maybe if u reflash the driver perhaps? but the light goes insane hot on that mode if not careful u can burn yourself… i will use simple mode for now…
I ordered a Nichia one since I have a ton of SST-20 lights… I have a Lumintop IYP365 with a really good tinted 4000k Nichia so I was hoping they’d use the same bin. Mine hasn’t shipped yet, it’s been “unfulfilled” for a week.
My SST20 4000k took 16days from order to doorstep. Beautiful tint……. love it. Ordered 5 Vapcell H10, was only sent 2 but was credited $15 for the three that I didnt get. Not sure what happened there but Im still happy. Thanks freeme!
