Interesting update, just when I bought a bunch of new Cree LEDs!
XHP50.3 Data and Binning & Labeling.pdf
Google Drive file.
Any idea when the datasheet will be available for the XHP50.3?
Parts are due for release around late May/June so expect data available in May,
Thanks
Hoping for less tint shift but not holding my breath! Domeless 50 has to be worth something at least.
XHP50.3 HI…Interesting…I thought it said XHP35 when I first read it. Let’s hope it has a good beam profile.
Getting close to these yet? Any updates?
Datasheet on line at
https://www.cutter.com.au/product-category/led-emitter/cree-led/cree-xlamp/cree-xhp/cree-xhp50/
cheers
Mark
Please let the xhp50.3 come in cct under 6000k!!
the biggest disappointment of my flashlight adventure yet is the awesomeness in power of the xhp50.2 and the torture that it is almost impossible it find i. 5700k, but more than that, it isn't made in anything below 5700k! With the xpl-hi 5d and 5A being so perfect, why can't their xhp50 be made with these cct?.
Do you mean the 3V version perhaps ? because the normal 6V/12V version can be found in CCT under 6000K, for example : https://www.mouser.fr/Optoelectronics/\_/N-5g5vZ1yzvvqx?Keyword=xhp50b&FS=True
They have 2700, 3000, 4000, 4500, 5700. The 4500K, one of the 3000 and 5700 are even 90CRI.
And the 3V versions (sofar? at least as mentioned in the datasheet) are only with dome and cool white, just like the XHP50.2
I don’t see it on that page…
Link is on the second banner.
Google Drive file.
Ah, I see. Thx.
Highlights of 50.2 vs. 50.3 differences:
XHP50.3 HI is available down to 3000K and up to 90 CRI, but you can’t have them both. The lowest CCT with CR>70 is 4000K
In ANSI bins (pages 15-17) yes, but in Easywhite bins they are listed with 90CRI down to 2700K (pages 12-14)
Right! That’s a very good news.
XHP70.3 datasheet
https://www.cutter.com.au/product-category/led-emitter/cree-led/cree-xlamp/cree-xhp/cree-xhp70/
Comparing XHP70.3 with 70.2 I see:
Thank you welight for these datasheets!
this is very useful data, thanks
Also from the XHP50.3 data sheet, “configurable to 3 V, 6 V or 12 V by PCB layout”
Finally, one emitter covers the entire voltage gamete. Why didn’t they do this from the beginning? Im looking forward to trying out the XHP50.3 HI in a few older flashlights that need upgrades.
With the 3V and 6V LEDs having the same pad layout, I don’t think that’ll be the case.
Anyhow, looks like we’ll have an updated 70.2 that’s a little throwier, and a 50.2 that’s much throwier. This will probably be a simple reflow to make the FT03 and other 50.2 lights a lot throwier without sacrificing too much output. Double the intensity as previous xhp50 iterations as they said.
