Which Fancy Metal for your FWAA?
that might happen too
after the fancy metals
Brass, Gotta go with C-3PO! All the way
I know I’m a PITA about this part of it but I just don’t EDC floddy lights. The sole reason for a 14500 FW to me is warm weather active wear or fancy clothes. The latter is why I’d bite on my vote (Ti-Cu) but a light weight and rugged 7075 with some throw would be my summertime go to.
I’d love to have one made of rhodium.
Of course, I’d immediately sell it for scrap, and retire… :smiley:
I feel the same way
how would you feel about a gchart
Sofirn SP10S “BLF edition” with Andúril 2 and AA capability,
it has one LED…
but, im not a sideswitch fan
thanks to all for voting in the poll
my take away is that the TiCu would make the most people happy
the 30% that voted Ti, would get some Ti in a TiCu
the 30% that voted TiCu, get what they hoped for
and the 18% that voted Copper, could be consoled by the TiCu Head
that is a total of 78% of respondents whose preferences could be partially satisfied by a TiCu run. (except the ones that hate TiCu… lol)
I look forward to the Fancy FWAA run
Side switches have three homes: on fat lights (3+18650), long lights, and extra stubby lights.
BUT…
The switch must be large, recessed, and easy located. Rubber covers preferred. These things are unlikely on a truly tiny 14500. The SC52 was a favorite zebralight of mine, but the diameter was pushing it for an AA.
An oring modded FW is really my preference.
The other way ‘round: Tail switches have their home in lights that you would hold in ’the tactical way’.
Acebeams L35 (and probably many other lights) is a nice example of how to do it right: Turbo on tailswitch, normal operation on side switch. Locating the switch is no problem if there’s a clip. I’m using the D4V2 and Wuben E05-I blindly, just like a SC5c.
I think more detail is required. a well-done side switch (zebralight SC6x series) is easily found. The whole light basically guides you to it. And I’ve never had an accidental activation. At the same time, a protruding side switch is a disaster in-pocket. And then there’s my Thrunite T10T V2, which I can hardly find the switch on despite indexing it with the clip.
I have a T10T V2 w no clip
the only way to find the sideswitch is with my eyes
fortunately, the FWAA does not have a sideswitch to worry about… lol
I would like a stainless steel FWAA. It is small enough that even in SS, the weight would be manageable.
here are the weights with battery:
FWAA Cu: 91 grams
FWAA Ti: 67.1 grams
FWAA aluminum: 55.2 grams
so, I got the Cu FWAA w sst-20 4000k
I like the FWAA a lot, and the LEDs are not green tinted like a 219c, so am debating buying another SST-20 4000k
should I get a Shiny Ti, or Ti CU? lol
maybe Ti for the weight, but comparing aluminum weight and cost, and considering the heat disadvantage, i would say ‘Ti not worth it’
(same for my bicycles :slight_smile: )
Seems like I missed the fun, I’m for titanium + copper - good tail and glass drop protection and normal heat dissipation, but between the titanium tailcap and the copper part with the driver, I would put a standard aluminum case :blush:
I can say from experience that Titanium is tough to machine, 15% heavier than aluminum. I also have an aluminum bicycle and its plenty light enough for me. Copper is also difficult to machine and tarnishes quickly.
sounds like your wish could come true if you buy one of each and lego them… :partying_face:
however,
Aluminium :confounded:
is Not Fancy… no Bling!
Im loving my Fancy Cu FWAA with Fancy Sapphire Lens, and Fancy Glow:
Bling! Bling! Bling!
Dances with Bling!:
Nice photos, Jonathan.
I went with Copper as well for my FWAA. Seemed the logical choice, as the others like titanium and steel would be awful for heat management in this very tiny light.
Well, if only polished aluminum like a mirror or coated with nickel))
Yes, I remembered 1 problem with a combination of copper / steel / aluminum / titanium, I don’t remember exactly, but some of these metal pairs tend to diffuse into each other in a threaded contact, so it will be difficult to unscrew, need to lubricate often
This light is small enough and nice enough that I think a Timascus run would be viable.
2xAA in Beryllium/Copper alloy.
(one can dream right?)
TiCu as always but with 219B emitters
