【convoy】H4 and B35AM options are updated
I havent been able to find those two data sheets anywhere online... only sft20, sft10, and sft colors.. The -40 and -70 seem nonexistent. I've looked a couple of time since ordering this light.
yes
SFT40 datasheet
SFT70 datasheet
Thank you for the links Simon. I also googled and could not find the datasheets so these links are appreciated. I'm anxious to try these out.
Thanks Simon!
wow.. if you look at bottom of page #1 on both data sheets, in "applications" the first thing Luminus lists is FLASHLIGHTS. I've never noticed that on other data sheets before!
EDIT: never mind i see it says the same thing on the sst40 datasheet too...
also, looks like sft40 = 3v, sft70= 6v / 12v.
Hi Simon, thanks for the datasheets. Can you sell us sft-70 leds also?
Thanks for the datasheets, Simon! I was about to ask if you could share them again since the previous hosting links are dead. Been very curious about the SFT40.
The links are working for me.
Yup, me too.
I meant the handful of links from some weeks/months back in previous posts
What’s the advantages of these sft40? I read the data sheet but I don’t know what to make of it.
Factory dedomed SST40 which gives a good increase in range
Any chance of warmer color temperature like 5000k or 4500k SFT40 being available for sale?
Thanks!sounds good.
How about that fct40? Edit: I meant fc40
If this follows what happened to the SST40, here may be a 5000K at some point but not lower, and only low CRI versions.
I really enjoy the balance between flood and throw in SST40. I guess SFT40 will be a bit floodier than CULPM1, but I wish someone post a beamshot comparison.
Looks like the SFT40 has 4 bond wires. Not sure I’ve seen that before; a bond wire at each corner of the die. If that is the case that should mitigate the burning bond wires failure mechanism of the SST40.
Thought that was only with the SST40 Gen 1?
SFT70 LED will not be available until next year
I have put forward this suggestion to the manufacturer, but I think it is difficult to implement.
