Nope, it’s thoroughly waterproof, even from the inside. :laughing:
Seriously, battery tube from head was a chore to unscrew, so drizzled detergent down the hole and completely drownded it in hot water coming full blast from the faucet. Once I did unscrew it into 3 pieces, I was able to completely clean out everything.
No condensation under the glass, not a hint of fogging, nuttin’.
Dropped in a LFP cell (had it handy), and it still worked fine.
I had a pair of ’123s go all China Syndrome in my MH20 for some reason. Both wraps were split and crinkled, both cells down to almost 0V, but no leakage. Nfi how that happened.
No, all li-ion are not protected, in fact none are from the factory to the best of my knowledge. The protection circuits are added post production and re-wrapped. All have intentional weak spots to reduce the violence of venting from the factory, so actual explosion is not what they do. normally. IMR, and INR chemistries are less volatile than the ICR that was used previously. Usually a battery venting might have fire but not an explosion. Inside a light there is less oxygen, so I am not surprised a tiny 14500 did not have flames. Had the same happened in a light containing 4x18650 cells it might be different. Had this been an ICR battery, it might have been the kaboom you speak of, but the stored energy of a 14500 is not going to be enough to be an extremely impressive kaboom. The fact that the cell vented without flames at all is fortunate even with IMR, and INR. You can easily see on the internet, videos of controlled intentional ventings by doing insane things like dead shorts or hitting them with hammers, with sometimes less than impressive results. That being said, even the INR and IMR can if venting cause flames. It can, if depleted too far, cause venting and flames if attempting to recharge. That is why most chargers, will refuse to recharge batteries that are too low in voltage. Some expensive re-chargers have special re-charge teqniques to recharge very depleted cells, but I would not risk it. I have had a house fire before, so I tend to take li-ion batteries and their potential dangers very serious, and do not push the envelope with their use. If a battery is too depleted to accept normal charging, I toss it. I do store some batteries in single cell devices with the tailcap loosened, but most I store in plastic boxes. None are stored long term in multicell devices. It is not that hard to remove them and put them in 2 cell plastic boxes for their storage. I have never seen or heard of a battery self depleting, and then venting due to low charge, and better li-ion batteries can hold their chages for years in storage…self depleting very slowly. Most violent venting events are due to the batteries mis-use or as in videos, intentional acts.
A lotta people have lights all over the place with cells in ’em: in drawers, in the garage, in the basement, scattered all over the place like they’re old plastic D-cells-and-hotwire-bulb flashlights, and if you forget the check on ’em, or forget about them completely, that’s exactly what can happen to them. Best case, the cells take a dump and ruin the light, but worse case?
I only keep cells in a haldful of lights, that those that are in daily use, and only a (very) few that go in’n’out of rotation. All of the latter, though, are tailcap-locked-out.
Had Tenergy 9v. NiMH melt inside a device last week. It was not the device’s fault. Put a new one in and works fine. What would cause it to melt is beyond me.
How old was the 14500 battery and where did you get it from? Seems strange that a small drop would cause the battery to leak. And when was the last time it was charged?
Glad it didn’t ruin your GT Micro (and perhaps your cat saved it)!
Can’t say it was a drop, as he knocks things over all the time. Either swinging his tail around, or rubbing his face on things. Nothing to purposely knock things over like you see some cats do.
Don’t recall when it was last charged. Blinked out 3.6V a few days before, which is about when I’d top it off When I’d Get Around To It.
I’m hoping so. I always keep ’em facing me (lit sideswitch) so I can see where they are in the dark, and it was fine one day, dark the next.
Holy $hit, EXACT same thing happened to Max (13 YO and still with the living) Saw the idiot chewing an extension cord and it shorted in his mouth. Damn cat must’ve jumped 4 ft in the air. Not sure if his lips were burnt because I didn’t check. Hasn’t happened since…Stupid Max
There is no mistaken it. All you saw were teeth looking at him. My memory is getting bad. It wasn’t my cat but someone I knew. Either way, curiosity almost killed the cat.
i have 3 cats, all are beasts, all have awesome personalities, I keep NO light on ANY shelf. Ever. I keep all my lights either on display with batteries or in my drawer with batteries, all I look at/check every day and the cats couldn't touch if they wanted to. Believe me, they want to lol. Then again my collection isn't hundreds of lights. It's tens of lights..
Lightbringer, I want to remind you that Li Ion battery electrolyte contains hydrofluoric acid.
It has excellent absorbtion by skin contact and won’t cause pain.
But it will start eating your bones (calcium).
Of course, quantity and length of exposure play a big role in how severe it is but you’d rather read up on it or talk to a doctor, it’s scary stuff.
IIRC the “antidote” is just big quanities of supplemental calcium so the acid eats that instead of your bones.
Hope you’re well!
Likely it’s already out of your body but it might be worth looking into.
