You must only mean 1 special case of 2 emitters. Do you mean when there are 2 identical side by side emitters? Because there are a whole lot of lights with a pair of different emitters.
1 white and 1 aux color is pretty common. So is 1 flood and 1 throw . Often an emitters points forward while the other is an anglehead so the light can be both . Having a pair of emitters greatly increases the flexibility of the flashlight and it is pretty popular.
zoulas
(zoulas)
June 21, 2021, 4:41pm
10
I meant primary not aux.
Also most of the lights mentioned are two single emitters in one unit.
goshdogit
(goshdogit)
June 21, 2021, 4:53pm
11
I had to make this one myself.
See where you’re going and where you’ve been—simultaneously! And at the same time!
Yes, it works! The battery carriers are back to back and insulated from each other.
goshdogit
(goshdogit)
June 21, 2021, 4:52pm
12
Lupine makes a couple side-by-side models. Hide your wallet.
Not space-efficient.
1 emitter, you can size the head/reflector up/down as you want.
3, 4, others, you size the head up/down, and stuff the LEDs regularly in a circle.
5 would be wasteful (quincunx shape) unless the center LED’s reflector/lens is reeeeeally small.
2 is by necessity a 2:1 rectangle. If you stick ’em in a circular head, there’s wasted blank space above/below the side-by-side LEDs.
Unless you want to buy a 2-emitter light at the Darth Mall.
Only reasonable 2-emitter light would be with 2 cells side-by-side as well. And those are all weirdo designs, so it’s not surprising it’s rare.
goshdogit
(goshdogit)
June 21, 2021, 5:42pm
14
Lightbringer:
(quincunx shape)
Good points, LB, and you taught me a new word!
zoulas
(zoulas)
June 21, 2021, 5:58pm
15
So, from Algebra 101, we can conclude if A=B and B=C then A must equal C no?
Similarly , if LB taught you, then who taught LB? Its a mystery . LOL
If you go back far enough, you will find a caveman holding what seems like a flashlight. On it will read “Ever Light Bringer Edy.”
zoulas
(zoulas)
June 21, 2021, 6:17pm
17
Yokiamy:
exactly
That would be two single emitter lights in one.
In a pinch, I would “palm” a headlamp, so youse can use a D25 like that.
Scallywag
(Scallywag)
June 21, 2021, 8:14pm
19
Lightbringer:
The Darth Mall.
I think that’s your best one yet.
goshdogit
(goshdogit)
June 21, 2021, 9:49pm
20
I chuckled, and I don’t even like Star Track.
That’s where I got my last light.
Turned it on, almost got a 2nd bellybutton.
goshdogit
(goshdogit)
June 21, 2021, 10:10pm
24
Lightbringer:
Dr Smith is displeased.
The guy with the elf ears who flashes gang signs? I thought his name was Dr. Spork.
Dr. Spork with his 1-emitter light that he got at the Darth Mall (in the Star Track Universe.)
richbuff
(richbuff)
June 22, 2021, 1:13am
26
One of the first pop can flooders, if not the first, the Niwalker MM15 2 x MT-G2, is a two emitter light. I waited until November, 2014 to latch onto it. The review by Selfbuilt mesmerized me for weeks. So many happy memories!
Click here for detail - NiWalker MM15
Coupon - DualMTG2
Technical specifications
Light output / runtime
Mode 1 : 6 lumens
Mode 2: 180 lumnes
Mode 3: 450 lumens / 24 hrs
Mode 4: 880 lumens / 9 hrs 25 mins
Mode 5: 1950 lumens / 5 hrs 17mins
Turbo: 5233 lumens / 2 hrs 10 mins
Max beam distance: 280 meters
Peak beam intensity: cd: 19.600
[image]
[image]
[image]
Manker ML03
https://www.aliexpress.com/item/1005001769454212.html
RovyVon E200 series
The Angel Eyes E200 series includes 3 models – E200u, E200s, and E200r. The E200u uses a dual-chip LED which makes UV-C (270nm) and UV-A (390nm-400nm) available on the same LED. The E200s uses 6500K cool white LEDs for both front and sidelight. And...
Price: USD 79.95
ArtieT59
(ArtieT59)
June 22, 2021, 2:30pm
28
