goshdogit
(goshdogit)
June 21, 2021, 5:42pm
14
Lightbringer:
(quincunx shape)
Good points, LB, and you taught me a new word!
zoulas
(zoulas)
June 21, 2021, 5:58pm
15
So, from Algebra 101, we can conclude if A=B and B=C then A must equal C no?
Similarly , if LB taught you, then who taught LB? Its a mystery . LOL
If you go back far enough, you will find a caveman holding what seems like a flashlight. On it will read “Ever Light Bringer Edy.”
zoulas
(zoulas)
June 21, 2021, 6:17pm
17
Yokiamy:
exactly
That would be two single emitter lights in one.
In a pinch, I would “palm” a headlamp, so youse can use a D25 like that.
Scallywag
(Scallywag)
June 21, 2021, 8:14pm
19
Lightbringer:
Not space-efficient.
1 emitter, you can size the head/reflector up/down as you want.
3, 4, others, you size the head up/down, and stuff the LEDs regularly in a circle.
5 would be wasteful (quincunx shape) unless the center LED’s reflector/lens is reeeeeally small.
2 is by necessity a 2:1 rectangle. If you stick ’em in a circular head, there’s wasted blank space above/below the side-by-side LEDs.
Unless you want to buy a 2-emitter light at the Darth Mall.
Only reasonable 2-emitter light would be with 2 cells side-by-side as well. And those are all weirdo designs, so it’s not surprising it’s rare.
The Darth Mall.
I think that’s your best one yet.
goshdogit
(goshdogit)
June 21, 2021, 9:49pm
20
I chuckled, and I don’t even like Star Track.
That’s where I got my last light.
Turned it on, almost got a 2nd bellybutton.
goshdogit
(goshdogit)
June 21, 2021, 10:10pm
24
Lightbringer:
Dr Smith is displeased.
The guy with the elf ears who flashes gang signs? I thought his name was Dr. Spork.
Dr. Spork with his 1-emitter light that he got at the Darth Mall (in the Star Track Universe.)
richbuff
(richbuff)
June 22, 2021, 1:13am
26
One of the first pop can flooders, if not the first, the Niwalker MM15 2 x MT-G2, is a two emitter light. I waited until November, 2014 to latch onto it. The review by Selfbuilt mesmerized me for weeks. So many happy memories!
Click here for detail - NiWalker MM15
Coupon - DualMTG2
Technical specifications
Light output / runtime
Mode 1 : 6 lumens
Mode 2: 180 lumnes
Mode 3: 450 lumens / 24 hrs
Mode 4: 880 lumens / 9 hrs 25 mins
Mode 5: 1950 lumens / 5 hrs 17mins
Turbo: 5233 lumens / 2 hrs 10 mins
Max beam distance: 280 meters
Peak beam intensity: cd: 19.600
[image]
[image]
[image]
Manker ML03
https://www.aliexpress.com/item/1005001769454212.html
RovyVon E200 series
The Angel Eyes E200 series includes 3 models – E200u, E200s, and E200r. The E200u uses a dual-chip LED which makes UV-C (270nm) and UV-A (390nm-400nm) available on the same LED. The E200s uses 6500K cool white LEDs for both front and sidelight. And...
Price: USD 79.95
ArtieT59
(ArtieT59)
June 22, 2021, 2:30pm
28
max
(max)
June 22, 2021, 8:08pm
29
richbuff:
https://budgetlightforum.com/t/-/26319
That brings back memories indeed! Still got a couple of these Niwalker MM15s - one from Vinh - and successfully dedomed my first MT-GT leds with this light to give a bit more throw.
Ooh, I hadn’t seen that before but I kind of want one. I love the MTG-2, and two of them must be better than one.
zoulas
(zoulas)
June 22, 2021, 11:32pm
31
Again, both are single emitter lights. 2 in 1 lights.
nbjly
(nbjly)
June 23, 2021, 10:16pm
32
I think what the OP meant was something like this -
free image hosting reviews
goshdogit
(goshdogit)
June 26, 2021, 1:11am
33
I now understand that these aren’t the kind of lights zoulas is after, but I can’t help posting this MAXTOCH OWLEYES W1 I just discovered.
