zoulas
(zoulas)
June 21, 2021, 5:58pm
15
So, from Algebra 101, we can conclude if A=B and B=C then A must equal C no?
Similarly , if LB taught you, then who taught LB? Its a mystery . LOL
If you go back far enough, you will find a caveman holding what seems like a flashlight. On it will read “Ever Light Bringer Edy.”
zoulas
(zoulas)
June 21, 2021, 6:17pm
17
Yokiamy:
exactly
That would be two single emitter lights in one.
In a pinch, I would “palm” a headlamp, so youse can use a D25 like that.
Scallywag
(Scallywag)
June 21, 2021, 8:14pm
19
Lightbringer:
Not space-efficient.
1 emitter, you can size the head/reflector up/down as you want.
3, 4, others, you size the head up/down, and stuff the LEDs regularly in a circle.
5 would be wasteful (quincunx shape) unless the center LED’s reflector/lens is reeeeeally small.
2 is by necessity a 2:1 rectangle. If you stick ’em in a circular head, there’s wasted blank space above/below the side-by-side LEDs.
Unless you want to buy a 2-emitter light at the Darth Mall.
Only reasonable 2-emitter light would be with 2 cells side-by-side as well. And those are all weirdo designs, so it’s not surprising it’s rare.
The Darth Mall.
I think that’s your best one yet.
goshdogit
(goshdogit)
June 21, 2021, 9:49pm
20
I chuckled, and I don’t even like Star Track.
That’s where I got my last light.
Turned it on, almost got a 2nd bellybutton.
goshdogit
(goshdogit)
June 21, 2021, 10:10pm
24
Lightbringer:
Dr Smith is displeased.
The guy with the elf ears who flashes gang signs? I thought his name was Dr. Spork.
Dr. Spork with his 1-emitter light that he got at the Darth Mall (in the Star Track Universe.)
richbuff
(richbuff)
June 22, 2021, 1:13am
26
One of the first pop can flooders, if not the first, the Niwalker MM15 2 x MT-G2, is a two emitter light. I waited until November, 2014 to latch onto it. The review by Selfbuilt mesmerized me for weeks. So many happy memories!
Click here for detail - NiWalker MM15
Coupon - DualMTG2
Technical specifications
Light output / runtime
Mode 1 : 6 lumens
Mode 2: 180 lumnes
Mode 3: 450 lumens / 24 hrs
Mode 4: 880 lumens / 9 hrs 25 mins
Mode 5: 1950 lumens / 5 hrs 17mins
Turbo: 5233 lumens / 2 hrs 10 mins
Max beam distance: 280 meters
Peak beam intensity: cd: 19.600
[image]
[image]
[image]
Manker ML03
https://www.aliexpress.com/item/1005001769454212.html
RovyVon E200 series
The Angel Eyes E200 series includes 3 models – E200u, E200s, and E200r. The E200u uses a dual-chip LED which makes UV-C (270nm) and UV-A (390nm-400nm) available on the same LED. The E200s uses 6500K cool white LEDs for both front and sidelight. And...
Price: USD 79.95
ArtieT59
(ArtieT59)
June 22, 2021, 2:30pm
28
max
(max)
June 22, 2021, 8:08pm
29
richbuff:
https://budgetlightforum.com/t/-/26319
That brings back memories indeed! Still got a couple of these Niwalker MM15s - one from Vinh - and successfully dedomed my first MT-GT leds with this light to give a bit more throw.
Ooh, I hadn’t seen that before but I kind of want one. I love the MTG-2, and two of them must be better than one.
zoulas
(zoulas)
June 22, 2021, 11:32pm
31
Again, both are single emitter lights. 2 in 1 lights.
nbjly
(nbjly)
June 23, 2021, 10:16pm
32
I think what the OP meant was something like this -
free image hosting reviews
goshdogit
(goshdogit)
June 26, 2021, 1:11am
33
I now understand that these aren’t the kind of lights zoulas is after, but I can’t help posting this MAXTOCH OWLEYES W1 I just discovered.
L4M4
(L4M4)
June 26, 2021, 7:55am
34
I know that this isn’t the light OP is searching for, but this thread seems like the right place for it - the Warsun X608 with 2x Osram P8 and a side-firing COB and inbuilt battery + powerbank function.
16$ with a code from Fin17: Archive topic - Banggood & Fin17
I have this light and I really like it.
It’s not easy to disassemble, but the batteries are really 4Ah, the light colours are all not blueish, the UI is good and the light gets warm after a short amount of time, to the LEDs are all cooled.
Only negatives are the micro-USB port instead of USB-C and that it’s not disassembleable without being destroyed.
Perfect for testing out if that formfactor is suitable for you.
