Marco 1lumen just published 891,000 cd 1888m in his review. David and I got close to 1800m, so I shouldn't think there is much to dispute on Lumintop ratings.
Interested in SS.
ArtieT59: Th558:For the THOR II, Vinh got 195Lumen, 550Kcd, 1483m which is way below spec. Has anyone else tested it? Hopefully this one doesn’t underperform as well. Edit: It does actually hit the claimed 1.8km so this might hit the claimed 1.2km too.
I saw Vinh's measurements too and wondered why they were SO below spec? worried me actually, especially since freeme claimed to get 1700+ meters. Then again, VInh has really questionable measurements for the FireFlies e12r with sst20 4000k, something like 3800 lumens, which doesn't make any sense (even @ 450 lumens/emitter which is a low average, that is 5400L). so maybe another biffle on his part? or he doesn't understand how to operate Aunduril 2 (in all seriousness, its quite different and comes in on "muggle" mode).
You edited and said that Thor II did hit spec, where did you confirm this if you dont mind i ask?
great to know! I have no issues with that, I was just curious.
Throw distance: 1170m
Intensity: 3,420,000Cd (30m)
Seems like a typo. By the throw distance, it is probably 340kcd, one less zero.
Interested
My fault, it has been corrected. They are really testing my vision when report label it as "342000CD(30m)". Should have recalculated with my xlsx table before publishing.
freeme:
- Throw distance: 1170m
- Intensity: *3,420,000Cd (30m)*
Interested
List updated.
List updated.
I never seem to end up on the interested list… I was post 51 and indicated I was interested. :cry:
Definitely will buy an aluminum version
Interested in Ti and black
Noted.
Definitely will buy an aluminum version :+1:
Interested - thank you.
1200m verified.
Would be great to have an e-series compatible lep head module
I an interested in anodized aluminum lep.
Noted.
All the LEPs are white. It’d be cool if they made a green, blue or red beam version.
You mean using colored filters or replace with Osram LED?
