I was gonna say Adam Driver’s and Minnie Driver’s cousin, but…
Now you can order 4000K, or 5000K on our website.
Wurkkos Terry: lfb:There is any estimate of when reviewers will start to receive samples? I’m just curious to see it.
What would you like to know?
So, Wurkkos, you lied about the driver.
See the post above where the test showed PWM and you said initially it is buck driver.
Do you know what buck driver is?
Do you mean constant current?
TexasToasted: Fescron: Wurkkos Terry:6500K for this batch.
Aah that’s too bad but I get it, guess I’ll order one later
Yup. I like this light, but I already have a pile of lights that need the cool white emitters replaced and I’m getting tired of swapping LEDs. I’ll order one when it has neutral/warm LEDs.
Hi Terry, I’m from Malaysia and usually order from your official Lazada online store. Will you be offering these tints on your other official online stores soon?
Wurkkos Terry: TexasToasted: Fescron: Wurkkos Terry:6500K for this batch.
Yes, you can order tomorrow from Lazada.
darosk: Wurkkos Terry: TexasToasted: Fescron: Wurkkos Terry:6500K for this batch.
What great service! Thanks Terry
id30209: Wurkkos Terry: lfb:There is any estimate of when reviewers will start to receive samples? I’m just curious to see it.
Yes.
So what driver you have in it?
I’ve got my sample. Moddable 100%.
First i was surprised seeing thin white sticker over the MCPCB but when i removed it i saw the green light from the switch so it’s sole purpose is to hide it.
Now i need to swap emitters to some nice high cri.
Ooh nice thanks for the pictures! Did you dig any deeper? So the driver is visible?
Driver is visible from the back side of the head and it looks like it’s glued. Applying some heat to soften the glue will help you removing it but i won’t do that now. Later maybe.
Can you post image to see back of the driver. It interesting to view is there any pins for flashing firmware.
Unfortunately, there are no flashing pads on the driver board.
Thanks :+1:
No pads...
Is there any further information on the driver?
Seems like the driver has a vertical board. There might be a chance that the attiny is accessible through the switch cutout. Like I did with the SC31Pro: Sofirn SC31 PRO, New Anduril Flashlight - #308 by SammysHP
I’m sure it does have vertical board. I’ll try to open it next week and update results here.
Will there be an option for a short tube add on with Amazon?
Wurkkos Terry:Any other improvement you would like to see on it?
Yes. # Matte anodizing or raw aluminum. #2 The pocket clip. Please use a one way deeep carry pocket clip. Deeper than the current design. Please refer to the new Noctigon KR4 clip: !{width:60%}https://intl-outdoor.com/media/wysiwyg/KR4TI/IMG_3604_1100px.jpg! Notice a few things: * The clip reaches the end of the flashlight * The starting / open end of the clip has a standoff that allows fabric to easily slide under when inserting it into the pocket. * One direction clip. You already have a second mounting groove near the head for reversibility, don’t make a redundant and bulky clip. #3 Increase the opening of the bezel so that it’s not blocking any light from the optic. Looks like it needs an extra 1-2mm or so in the pic below. !{width:15%}https://i.ibb.co/42PNF96/bgghy41az5t61.jpg! #4 Make 100% sure this optic is compatible / swappable with Carclo 105xx optics.
For improvements, JaredM covers everything i would like to see in an improved version, especially regarding the optics being Carclo or at least Carclo compatible, a one way clip (no 2-way clip needed, it gets caught on everything and no one is putting a 21700 light on their hat lid), and raw anodized finish!
