Do you ever give discounts/coupons for the USB testers in your ali store? Small order, not enough for any of the coupons shown on the site right now. I'm still browsing the options but think I might want a TC66C, possibly another model in addition. I can buy some of these on Amazon US from various sellers but I usually prefer to buy directly and wait. :) I like that the TC66/C can measure below 3.8v with the power assist.
thank you so much for your support
as you really like our products, I can give you 1usd discount , you can contact me aliexpress shop, we can talk there
https://www.aliexpress.com/item/32968303350.html?spm=a2g0s.12269583.0.0.3ce5b07fb7pTRR
Ok, will do! Tomorrow probably when I get time and will browse a little more (looking at videos of the products, too). Thank you!
ok, you can contact me at any time
do remember to use the black and green battery charging terminal to charge a battery, please, if you use the red terminal and connect the battery in the wrong way, it is a big problem
please do remember to use the green battery charging terminal as positive output to charge a battery, it has many protection method for battery charging including wrong connection, battery detection and auto cut off
if you want to charge the battery with RD6018, just use the Green and Black terminals to do that, the red positive terminal is not suitable for battery charging because it does not have protection method inside, and when you are using the battery charging terminal, it does not matter even you connect the battery in the wrong way, and it will cut off the charging when the current is decreased to 100mA
after 6 hours. we will release some 6 USD coupons, please wait
if you have good design based our power supply, just send us, thank you for your sharing
RD6018W order suggestion
when making order, you can click the coupon option to get more discount, for example, you order RD6018W, you can use 6 USD coupon, if you order whole set, you can get 10 USD off at least
