X9R has been around for a while. Marauder 2 came after it. The only thing that’s new is that it’s blue now. I imagine they will continue to carry both models. The X9R will go back up to $600 when the sale ends.
Hi TA, It is possible for a "mere mortal" without too much experience to be able to disable the charging on the carrier ... I wish I could do it because I always use a spare pair of batteries and I prefer to recharge the batteries with my charger.
Excuse me how do I tell the lamp 18 °? I can calibrate the external temperature or the temperature of the room or you are telling me that after heating the lamp with the Turbo for a few minutes I tell him that the room is at 18 ° so that it who is hot thinks that all that heat is only 18 °, is that correct? Thank you.
Easiest way would be to simply replace the charging PCB with a pass-thru board. Should be cheap but Int'l shipping is always a problem. We do need the PCB board designed, then anyone could order it through a PCB service like OSHPark or a China based low cost PCB house like https://www.pcbway.com/. Not sure of the cost, but probably over $10 shipped.
This is about Anduril, not the WT90 flashlight as shipped.
With Anduril, to calibrate temperature, you tell it what the current light's temperature is by clicking "nn" times, like 18 times for 18C. So what he's saying is to calibrate the light way under what the true temperature is, therefore it effectively disables thermal regulation because if it's set to trip at 50C and the real temperature of the light is 50C, the processor thinks the temperature is only 5C, for example, and won't drop the output via thermal regulation.
Btw, I just quoted a 50x50 mm PCB at PCBWay.com and it came to $5 for qty 5, plus shipping. USPS shipping for US is $10 but there might be a cheaper option with them.
Qty 5 is minimum, but qty 10 costs no more. I'm not sure this board can be made and quoted that cheap though - might depend on other options, for example, if the thickness is greater than 1.6 mm, the price goes to $53!
In the end, I believe that paying VAT and shipping from China is not worth it. I am waiting for an already modified carrier that I believe will arrive sooner or later and I will buy that directly, by the way why don't you propose it to us TOM E, it would be a pleasure to buy it from you.
I asked if they have the PCB design files for the charging PCB. If so I should be able to modify them pretty easiely and could order a batch.
If not then it becomes much harder simply due to the precision that the mounting holes have to be and it being hard to properly align said holes. It can be done just a lot more work to start from scratch.
Easiest maybe is if a pcb design is uploaded to Oshpark , even with the newest tax rules my guess is that it is around 10 dollar shipped worldwide. The only downside that you get 3 pieces instead of one.
1.6mm should be fine, the end cap on the carrier supports the load so no need for a thicker one.
Wildfire said they are going to try to send me the PCB files next week, assuming they are in a format I can use I should be able to edit them to delete the charging circuit pretty easily.
It could then be uploaded to oshpark although they can be expensive for larger PCB’s like this.
