Sounds promising. :) Do you have some Samsung 25S or 20S to test with again? These are supposed to be the most powerful 18650 cells available. If D18 219B works with them properly, there should be no way of killing these LEDs. :D
How many 219B SW30 and SW45K do you have left?
Oh and by the way, Hank did you have any chance to take a look at my previous post?
Default original optic back in stock for D18. Also can now select Nichia 219BT-V1 3500K and 4500K emitters. Order placed.
Hoping for tint below BBL with nice light pink hue, Thanks to Hank Wang for all your efforts. You are the best!
it is not "out of line" to send him an email (reply to your order confirmation) asking for update. After 10 days I would send one to check in. That's not unreasonable. I've done it once or twice before .
We have one D4V2 in Australia, 219B 4500K LED, with flat retaining ring, extra flood optic, 18350 tube, and magnetic tailcap, original price is $60.17, now, 30% off, which is $42, shipping included, for Australian customers only, PM me if you are interested. ———Sold
My sincerest apologies, I must have missed your post the first time around. I know I’m super late but I figured I’d at least answer your question in case you’re still wondering.
If you want excellent output, I imagine the K9.3 shoud be pretty good, maybe even the DT8. If you want super output, the D18 would be King. If you want sumtin pretty and mega output isn’t a major factor, def go Copper D4V2 all the way, or I guess the Raw Ore. Again, my apologies for such a late response.
So unless I’m reading it wrong, it turns out the D18 with 219B’s, WILL in-fact surpass 10,000 lumen at turn-on? Roger that. :heart_eyes: :heart_eyes: :heart_eyes:
Here is some community data that should be pretty accurate, as an alternative to trying to read the tiny relative output graph from the Nichia datasheet:
Rather than just settle for the closest reported current, I did the math to interpolate and got 605 lumens per emitter. You also have to consider losses from the optics. I don’t know what optic the D18 is using, but a Carclo 10mm TIR is supposed to be 92% efficient with similar sized LED’s, so that makes it 557 lumens per emitter.
That would suggest right at 10,000 lumens, if it really is able to pass 48A at turn on.
That makes perfect sense iamlucky13. That would line up exactly with why Hank said 10,000 Lumen. He obviously knows to account for those things too, unlike me. But I understand this a bit more now. Sure almost 11,000 technically, but impossible for the light to actually put that out.
Reminds me of the the difference between what horsepower a car is rated for vs what horsepower the car can actually put out at the wheels. Thanks.
I noticed in one of the other posts that the 5000K E21A tested out to be a few hundred K cooler than the rated when driven in these torches. Does this hold true for the 4500K E21A?
