I ordered one just now. Now for the long wait again.
Should be arriving to some of you very soon. Looking forward to your feedback
For under $20 shipped with tracking I decided to say screw it an ordered one. Hopefully have it within a month, lol.
I got my 18650-Sipik 68 today!
Compared to the smaller one:
Front:
Both on Flood-Mode:
Zoomed in:
What I dont like is, that the 18650 Sipik gets hot very fast. After like 2 minutes it was nearly to hot to hold.
The beam is much bigger and a little bit brighter. I dont know whether I like it or not. I will have to wait until tonight.
@toppel: That was fast! When did you order? Nice shots also.
Thank you!
I ordered on 16th.
That was really fast, yes!
Thank you for sharing.
IMO that looks like just what the doctor ordered for me.
BIIIG flood and decent throw for pointing at stuff.
I am so bummed that I cant receive it while I am on this ship. I would have ordered 3 already.
About the heat: That is good. It means some decent heatsinking is working to keed the led cooled. What do you think about the modes??
I dont know if its good or not. But you can warm up your hands in winter with it :D
The flood is very big!
The modes..mhh I dont know. I forgot that it has modes and when I turned on the lowmode I first was like: WTF where is all the brightness?! Then I accidentally turned on the strobemode and i remembered that is has modes ;)
I like the smaller one without the modes better.
But i can live with it. I like the reverse-clickie.
I think it is worth every cent. Good quality. Impressive flood. Nice throw.
I put it on my cheap DMM and got 2.1amps on high.
I don't like the strobe so I was going to do a driver swap to a 2.8amp nanjg 105c driver however there is no heat sinking in the pill, the star is suspended by the edges of the pill only giving very little area for heat transfer. I will need to improve the heat sinking before upping the output.
which has farthest throw? still like the little brother better :)
The little one (SK68) with a 14500 battery appears to throw further as it has a smaller/brighter hotspot. The SK98 with its larger led die & small lens projects the led into a larger hotspot that does not look as bright but does put out more usable light.
I do really like both these lights especially for the money.
thanks, agreed both great lights at great price
You’re not alone. I dig the looks as well except for the SK58.
not a better throw? :(
Received mine today.
With a Panasonic NCR18650 I got +3.5A on High.
how does it compare to the 14500 sipik if you have one? could you take some beamshots?
For 14usd it isn't a bad choice overall.
The bad:
The focus isn't perfect. The focal point (in my sample) isn't reached if you don't unscrew a bit the first section of the head (putting the lens farther).
The lens don't work very good with XM-L angle (I supposed it before purchasing). On full throw you can see light around the proyection.
The pill is very bad dessigned. No aluminium under the star. The 20mm star is just holded by a plastic disc, and only contacts the pill on the edges.
With +3.5A at the tailcap, I don't think this is very safe for the led. Surprisingly, the flashlight gets hot pretty fast.
Threads on tailcap were gritty. Now cleaned & lubbed, feeling better.
The good
Flood area is like bigger, and brighter.
Can take long cells (protected panasonic NCR18650A)
Tailcap is looks serviceable.
More in the review...
P.S: Sorry for the typos and poor english
So are there better 18650 XM-L options. give or take a few dollars? I'm disappointed to hear the focus isn't too good. I was hopeful this would be a decent XM-L zoomie. I'm not as interested in flood. Yes, I understand XM-L isn't ideal for throw, however, it still provides much more output for a potentially over all better package.
call me crazy, but I've come to prefer these pills w/ a hole in the center
I have 1/2", 5/8" and 3/4" copper rod here and I drive that into the hole.
The laborious part is facing the rod. I need a lathe...
This also makes is possible to solder the emitter directly to the copper - which is a bit easier w/ a zoomie (instead of reflector) because it isn't as crucial that the emitter be perfectly centered.
The nice part about this light vs the 'new c55/c56' (aside from the switch) is that the pcb 'holder' and the threads are one piece, so at least there is a good heat path to the body...
Looks like this will be my next purchase, after a visit from the credit fairy
