X50 is going to be my next light. I am going to ask my favorite modder if he can replace the cells when the time comes. If he can't, I still want this light.
Are the cells 18650 or similar, or are they a special, unobtainable size?
Acebeam X50 cw
Very disappointed in the throw. Is not as much as the advertised 160Kcd or 800 meter. More in the region of 630 meter distance. The 40 000 lumens output seems correct.
I was unfortunately also quite disappointed with the X50 range.
Ultimately, I sent the X50 back to the dealer because the 800m was not nearly reached. Even the 630m mentioned by you I can not understand so. Likewise, the information about the runtime on turbo seems to be unfortunately also only marketing. Very sad, because the lamp is otherwise great in terms of appearance, processing, feel, fast charging and lockout switch.
Why Acebeam did not put deep reflector?
What is the point of using 8 emiters and to hold 6500 lumen compare to X45 with 4 emiters and 5000 lumen?
Not to mention 130$ for battery pack.
I personaly do not give a …. for lumen in turbo.
Yeah 130$ dollars for a battery pack that containing only 3 x 21700 batteries are really ridiculous. There is also no way that you will get 800 meter throw from this X50. I got the Imalent DX80 with a much bigger reflector and I manage to get over 700 meter of throw.
