I haven’t checked the difference between those o-rings.
However, I can confirm that the space inside the button boot and the top of the switch in an FWAA appears the same as in the FW3A. I have a large bag of o-rings and every one of my FW3As and FWAAs has received the o-ring mod using the same o-rings.
Basically, any o-ring mod that works on an FW3A should also work on an FWAA.
Remove the plastic nubbin from its socket on the inside of the rubber button boot.
Place the endcap on a table with the inside facing the ceiling.
Insert the metal button
Insert the rubber button boot
Insert the o-ring into the rubber button boot
Insert the switch PCB.
Insert and screw on the switch retaining ring.
Note that the FWAA has a small wide spring that sits around the outer edge of the button boot. It provides electrical contact even if the switch pcb is not snug. Make sure this is in position when reassembling. The FW3A does not have this spring.
Yeah, that makes sense to me, given how the switch cover diameter is nearly the same (the FWAA is like 1~2mm shorter) . I’ve not yet bothered to take apart my switch. It works so well, I don’t mind doing a quad click for electronic lockout.
The MacGuyver in me just got a stiffy. Thanks! :laughing:
Btw, speaking of enlarged…
I put a fat o-ring at the base of the body tube on my FW3A, just under the clip ring. Wow, does this extend the easy handling of this tube light. So easy to hold & manipulate. That… didn’t come out right. :laughing:
I think the idea of the tactical ring is that it makes it even easier to get a cigar grip, because the ring makes the ledge that stops your ring and middle finger even bigger.
Flipping the body tube would make the light harder to use with cigar grip I think. Doing so eliminates the ledge your fingers are supposed to grip.
flipping the body eliminates a need for a tactical ring
the flare on the flipped body serves to stop the light from sliding forward, plus it balances the grip towards the middle of the light.
the stock body position makes the grip area too far back towards the tail, it is not balanced, and the unflared body tube has a sudden ridge, that is not as comfortable, and not as secure as the flared end.
When using cigar grip without a tactical ring with the stock body position, I feel concern about dropping the light.
With the flipped body, the feel in hand is Much more secure.
Yeah, you could call it tactical, although I’m using a fully rounded o-ring, not flattened off. I like using this rather than flipping the tube. It’s a definite “ledge” for easy grab & hold.
fwiw, here is the center line for the two body positions
when I use cigar grip with the body flipped so the flare is towards the tail, the light does not slide forward.
With the stock body position, I can understand needing a tactical ring to prevent the light from slipping forward.
The body flare towards the tail, makes for a much more balanced feel, for me. I also like that I have no need to add any bulky, ugly, rubber parts to the body of the light. But thats just me
whatever makes you happy is good fwiw, here is the center line for the two body positions !! when I use cigar grip with the body flipped so the flare is towards the tail, the light does not slide forward. With the stock body position, I can understand needing a tactical ring to prevent the light from slipping forward. The body flare towards the tail, makes for a much more balanced feel, for me. I also like that I have no need to add any bulky, ugly, rubber parts to the body of the light. But thats just me
[/quote]
That just looks odd
Thanks for the detailed photos, Jonathan.
I don’t have any problem with grip slipping, as I have a bicycle inner tube on part of the body. The o-ring is more for easy pick up from the back end and finger manipulation:
So far I like it. I’ll see how it goes… if the o-ring turns out to be more obtrusive then I’ll ditch it for the body switch. Aesthetically, I like the current tube orientation.
Btw, I picked up some more of that Cape Cod cleaning cloth. It really does a great job on copper without being abrasive. It’s just a tad cheaper than the Sunshine cloth. FWIW, I have a 2-piece bag of the stuff that I bought about 20 years ago. One cloth was done. The other was still somewhat serviceable. I was able to use it on my FWAA with success (just did the tube, left the other parts alone, for contrast).
