Well, nothing that simple to the driver itself. Theoretically you could find a lower performing FET but that has other risks.
I'm cautious about downgrading springs. In lowering the amps to 8 or 9 for example, that's still a lot of amps for cheap springs and I'd be concerned about melting them, as I've seen/done before.
Don't ask me - I'm saying I would not degrade the springs. If anything, I would add thin bypasses. I don't trust springs unless they are from Hank or are "Blue" springs.
I should add the SFT-40 in my DD calculator ( Graphing Calculator - GeoGebra ) since it has a lower Vf than the SST-40, it helps see the effect of added resistance (but without knowing the current itās difficult to estimate the lightās resistance)
thank you for this info freeman- I will say that (very unscientific) that once the battery voltage dropped from fully charged to about 4v, the angry blue went away. So of course I don't know what amps it's pushing at that point, but it just be close to being ok, meaning hopefully not a lot of resistance needs to be added to eliminate angry blue on a fully charged 9.6amp rated Lishen cell. Wow.. that was horribly uneducated way to justify my use of "not a lot of" extra wire needed LOL
I'll reduce the wire to as much as 26 or 28 AWG, lengthened if needed. Without the ability to measure amps, it's difficult to test. I'll usually add a tail spring bypass just so that the tail amp readings I get on the clamp meter is what I expect to get with the tail re-assembled, otherwise it's guess work of how much is lost in the tail spring.
Another indirect way of measuring current is by measuring the voltage at the mcpcb solder points. This method has many issues to be aware of, but if care is taken to compare values at some normalized temperature, you can get an idea of roughly where your at and then can detect relative changes with mods. Useful if no other method is available.
Looking forward to throw numbers from the EA01. If they sold one with the SFT and 26800 tube and a linear driver to cap the current, itād be a hit IMO.
Sorry, melting meaning burning off the coating, deforming the steel. I've seen them collapse then breaks the connection because of the contraction. All depends on the quality and it's rare we can get specs on springs.
What battery did you use in your EA01? I also swap my SST-40 EA01 with SFT-40, with new and fresh charge gold Vapcell 21700 the emitter got burn after a few times on turbo modeā¦ black dot in the phosphor :person_facepalming:
Emitter peaked at ā10.2A in djozz's test. Not all emitters perform the same, and even if the differences are small with just one test we don't know where this one is at.
Setting the limit at 8.8A (in Convoy's ramping driver) is easy, just stick an R050 over the R005 sense resistor. With an R025, or two R050's in parallel over the stock R005, limit raises to 9.6A. Personally, I would stick an additional R050ā¦ or not care at all (whereas 10.2A is ā2630 lemons, 8A is ā2450, which is 93.156% of maximum output anyway).
I used a 9amp 1100mah Epoch 18350. everything was fine
but i was using a Lishen 21700 9.6amp 5000mah, and i got ANGRY BLUE led when fully charged. it was very bad, so i immediately set max stepped ramp to 120/150 and did not go into turbo on a fully charged 21700. once the 21700 voltage had dropped to under 4volts, going into turbo was fine.
But i had the idea of using this less powerful 18350 the other day and i feel like it is much safer. I have not had angry blue since that first day.
I just make a point to make changes Right Away to UI or whatever i can when i see that angry blue happening, becasue that black dot in phospher can happen quick!.
Gents, I need some advice. Seems I ordered the SFT-40 on a 20mm MCPCB. Not sure what that was for, thought Iād get the bare LED. So, is it advisable to use this part in an SST-40 Astrolux FT03? What else must or can be done? I measured about 6A with a 26650 that I ordered with this light. Surely it would be more fun with more amps.
6 amps is a bit low, dunno maybe the cell. But the SFT-40 has a lower Vf so if you got 6 amps on a SST-40, you should get about 7 amps on the SFT-40 in a FT03, but of course you can do better than that - spring bypasses would be the first thing I'd do. Think the FT03 uses a bigger MCPCB? If so, you'll have to see if the 20 mm will allow wire clearance, and if you want it secured down, maybe drill and tap screws.
Yes, thanks. I guess if it doesnāt fit, Iāll swap LEDs. Measured the double springs and had very low resistance, but I guess my meter is not good at measuring it. Will bypass it.
the ft03 has a 28mm board, it is possible to create clearance with 20mm board if needed but requires sketchy centering ring stacking. 20mm by itself does not clear the reflector bottom. I would 100% reflow the sft40 onto the original sst40 mcpcb from the ft03. Should have no problem with that.
