FastTech New Arrivals & Promotion
Be Ready To Get Summer Offer! 10% OFF SITE-WIDE SALE!
USE COUPON CODE: 10BACK
Aug 10th, 2021 - Aug 11th, 2021 (UTC-6)
I agree.
Also, Fasttech, do single mode and separate switch mode memory lights, too. And throwy quad-die lights are hard to find.
I agree with the first comment. Rusty Joe’s is an example of some products that are very different then a lot of the weird cheap stuff I see.
That’s not to dogpile on, I just had an order at about $100 for 2 lights from this thread. But please don’t make me unsubscribe because of really low quality stuff that even the MOST budget enthusiasts are not interested in buying.
Hello Rusty Joe and dthrckt,
Thank you very much for your comments and suggestions. We will try our best to improve it.
Fenix HM50R V2.0 Multipurpose LED Headlamp Flashlight
1*Cree XP-G3 S4 LED / 6-mode / 700LM / pure white & red light / 1*16340 / USB rechargeable / IP68 waterproof
The Fenix HM50R V2.0 is a rechargeable multipurpose headlamp. One 16340 rechargeable Li-ion battery is included to power it. This headlamp is power-packed throwing a 700 lumens beam to a maximum distance of 115 meters. The HM50R V2.0 is outstanding with its solid construction and lightweight size, plus it is detachable to be used as a mini flashlight. This rechargeable headlamp combines white and red lights, comes with a USB Type C charging cable and features an IP68 rating, all of which make the Fenix HM50R V2.0 perfect for camping, hiking or working in rigged environments.
Detachable structure - can be used as a flashlight.
Lockout function avoids accidental activation.
Premium type HAIII hard-anodized anti-abrasive finish.
Nice, nice, vapes for back to school? Someone didn’t think this promotion through :person_facepalming:
This is exactly the problem (see red highlighted quote above). Giveways should have no strings attached. Personally, I find campaigns like these a bit shady, especially in combination with a giveaway. If you want to encourage customers to buy more items, offer volume discounts ("buy 2 get 3").
From the BLF rules applying to commercial sellers:
I am sorry that we haven’t realized the rule before. We just deleted the giveaway post on the BLF. Sorry for the inconvenience caused here.
Nice rationalization.
When someone is informed that they are breaking the rules, they can immediately stop breaking the rules, or they can come up with a lame rationalization.
Sadly, most people choose the latter.
Fenix HP25R V2.0 LED Headlamp Work Light
1*Luminus SST40+1*Cree XP-G3 S4+1*Everlight 2835 LED / 10-mode / 1600LM / white & red light / 1*21700/1*18650 / USB rechargeable
The Fenix HP25R V2.0 is a rechargeable work headlamp that provides an ultra-long runtime of 400 hours on low mode. Powered by its included 5000mAh Li-ion battery, this headlamp can deliver a max output of 1600 lumens. There is a separate battery case located on the headlamp’s rear; this unique battery case includes a USB Type-C charging port for easy and fast charging. 60° tilt mechanism allows you to direct light where needed and the lockout function avoids accidental activation. For all-night exploring or work demands, the Fenix HP25R V2.0 headlamp never fails you.
1600 lumens spotlight and 400 lumens floodlight.
One Luminus SST40 white light LED, one Cree XP-G3 S4 neutral white LED and one Everlight 2835 red light LED; with a lifespan of 50,000 hours.
Included a Fenix ARB-L21-5000 Li-ion battery, compatible with a 18650 Li-ion battery.
Separately controlled dual switch for easy and fast operation.
USB Type C charging port for easy and fast charging.
60’ tilt mechanism directs the beam where needed.
ON THE ROAD M4 Mini LED Flashlight
Head diameter: 24mm
Tube diameter: 20mm
Interesting light. Does it have a magnetic tail cap like the M3 Pro?.
Your listings describe it as having 4 emitters when actually there are 3.
Hello again Fasttech. Also in your new arrivals you show the On The Road U16. Your listing describes it as being powered by by a 16340 or CR123A battery and having 4 XHP50.2 emitters with output of 2300lm. If these are correct specifications this is a very unusual and phenomenal flashlight. Can you confirm?.
I would say that it is a mistake and that the “4” refers to the the 4 “nucleous” that the XHP50.2 led has! Also, in such small light, there is no space for 4 of that leds, as far as I can tell :wink:
In the pictures you can see that the lights are triples and not quads lol.
Fasttech i would email the manufacturer and tell them off, i know the description is copy and pasted to Fasttech store from what the manufacturer specs. How can a manufacturer get it so wrong? Now you have to go and fix up 3 separate listings sigh!
That image is of the M4 while Notmyrealname was asking about the U16 :wink:
Different lights :wink:
This listing states 4* Nichia, 4* SST-20 but the pictures shows 3 LEDs lol
https://www.fasttech.com/search?ON%20THE%20ROAD%20M4%20Mini%20LED%20Flashlight
Sorry, you are right! I thought that you were referring to the question above about the U16!
You are right, something is wrong, the photo or the description :wink: I bet on the description!
I think they’ve confused the U16 specs with another light. Fasttechs flashlight listings have many errors like this.
2300lm from a tiny 16340 light would be amazing though (for a few seconds anyway). You’d have to use it with a lanyard otherwise you’d be dropping it when it got hot.
The M4 looks interesting and the claimed 1500lm is also impressive. I would like a magnetic tail cap though as that has been useful on my M3 Pro.
To be fair to Fasttech, in this case the specs are not wrong! Those are the specs provided by the manufacturer. I had access to some unreleased (yet) information and those specs match the original ones. The U16 has a XHP50.2 with 2300lumens and the M4 puts out 1500. The only thing is that the original information about the M4 states 4xLuminus SST20 and that seems to be wrong, according to the photo.
Let’s wait and see what is right and what’s not!!
