Update (August 17, 2021):
- Updated hex-file (correcting the NiMH glitch in Party Strobe) as been sent to Sofirn.
- New UI diagram draft to be used in the upcoming SP10 Pro manual
Just to be sure, this is (almost?) exactly the same as the diagram with all the fancy icons, but without those right? Looks way cleaner for sure! I like it! Also good to see the factory defaults, although I still miss the default temperature value If I may also add another thing, maybe add asterixes (*1) to the “set …” bubbles and explain them on the side? That way all of the information you need to use the light is available in one compact picture without having to read the whole manual
The button brightness settings are the same for both UI’s right? Although the SP10 Pro won’t have a button-LED I assume? And auto-lock is not available in simple UI? Overall I’m excited to use Anduril 2, I only use the battery check most of the time so Simple UI will be perfect for me
Ah yes just another thing, I suppose voltage calibration will need to be tested rigorously on both NiMh and Li-Ion voltages so it behaves exactly as expected? Or are there two different internal calibration values depending on the source voltage so this won’t pose any problems?
I need to double check, but I think you can set up auto-lock in Advanced UI and then put the light back into Simple UI.
Correct, no button LED.
There is only one voltage calibration value. In my sample size of 1 flashlight, the voltage reading was very accurate on both NiMH and lithium ion without any calibration. Of course some of that will depend on the accuracy of the voltage divider resistors themselves.
Oh, and one more great thing about the use of the AVR 1 Series: the thermal sensor is factory calibrated with both offset and slope values! In all of the 1 Series-based drivers I’ve put together, they seem to be spot on!
Yes, I wanted to sweep any unnecessary stuff and give it a cleaner look. :)
Factory default temperature is always 45°C if I am not mistaken. gchart probably knows way better than me. ;) I like a safe level for default since those people who ask for higher temperature limits are often those who can handle a complex UI quite well.
Agreed, but I am afraid it could turn the cleaner look into something more confusing. Instead, my intention is to offer detailed (yet essential) explanations for each function in the text manual of SP10 Pro. This manual needs to be kept short for Sofirn will offer it in not less than eight different languages.
OMG, how did I miss the fact that there was no switch button LED?
I will ask Barry if they plan to use the SP35 / IF22(A) switch which has an LED in the button. If I recall correctly, the original switch in SP10S was often reported to be mediocre. So, let‘s wait and see what they are going to use here. In the worst case, I will remove that part from the UI diagram and manual.
About auto-lock…
Good question, never checked before. According to ToyKeeper‘s text manual, auto-lock is a part of the Advanced UI only but maybe timer-settings are also being propagated to Simple UI as well?
Can confirm, auto lock settings do not carry over to simple UI.
Yup, I just confirmed the same using my customized SP10S with the proposed firmware.
I’m not sure how many people would want to use Simple UI with auto lock, but I don’t think it would be too hard to implement.
Yup, it looks like it would be a simple add. The question though is: should it’s inclusion be made it universal? or should it be a compile-time config option? TK clearly designed it to not autolock in Simple UI. So I would think if it’s going to be added in, it should be a compile flag. The setup of autolock would definitely still happen in Advanced UI, but I could see it’s config carrying over to Simple UI. (sorry, kinda thinking out loud there)
ToyKeeper/spaghetti-monster/anduril/off-mode.c
#ifdef USE_AUTOLOCK
// lock the light after being off for N minutes
#ifdef USE_SIMPLE_UI
if (! simple_ui_active) { // no auto-lock in Simple UI
#endif
uint16_t ticks = autolock_time * SLEEP_TICKS_PER_MINUTE;
if ((autolock_time > 0) && (arg > ticks)) {
set_state(lockout_state, 0);
#endif
#endif // ifdef USE_AUTOLOCK
Thank you gchart for this great idea. :THUMBS-UP:
I like this option, but…
to be honest, I fear that both Sofirn and some (many?) BLF members / customers would rather like Simple UI to be really „K.I.S.S.“ (keep it simple, stupid). Some “muggle“ users could get confused if their light locks out automatically. On the other hand, if auto-lock is not active in the factory defaults of the Advanced UI, it should not be of any concern.
How about a quick poll (1 week runtime) to see what people want most? I can ask Barry to hold on using the current firmware for there might be another one coming with auto-lock working in Simple UI, too.
Auto lock probably won’t be a good idea. Hand a light to grandparents and they’d just think it were broken. Anyone given a light in simple UI should be able to figure out how to use it immediately.
Even as an enthusiast and huge fan of Anduril - I agree, I think auto-lock should be kept out of the simple mode. But I also agree with the suggestion to put it to a poll.
Remember - auto lock would still have to be set up in advanced UI for it to carry over to simple UI. There would be no danger of someone accidentally enabling auto lock from within simple UI.
Active Poll #1 for 7 days from now on:
Would you like Auto-Lock to be integrated in Andúril 2 Simple UI?
https://budgetlightforum.com/t/-/72913
Active poll #2 for 14 days from now on:
What anodizing do you prefer for SP10 Pro?
https://budgetlightforum.com/t/-/72914
I agree with the points that have been made: keep Simple UI simple. I voted no.
The driver will have flashing pads. If anyone really wants this as an option, they could flash some custom firmware.
Aah yes you’re right I forgot about that part, guess I’ll do that then :innocent:
+1
I intend to use post #2, currently empty, for (alternative) firmware repository links and download links to the manual/UI diagrams.
Moreover, additional information how to build a suitable flashing adapter or where to get a possible Sofirn-made adapter could be posted there, too.
Great work
Hope the next project will be the SP35 Pro where it will be the similar big brother of the SP10 Pro
I think its Dangerous and irresponsible to have Simple come with a 150/150 ceiling, AND no lockout…
The FWAA Simple mode also has a 150/150 ceiling.
but
The FWAA Simple mode Does have Lockout….
I just tested it… I know Im in simple cause triple click from off, gives battery level only once, and triple click from On does nothing.
imo Simple should NOT come with 150/150 ceiling
First off, no one is saying that Simple UI won’t have lockout. I think you might have misread something. What we’re talking about is auto-lock in Simple UI, which I feel will probably just get confusing and is why it was excluded from Simple UI in the first place. The normal lockout mechanism will still exist in SP10 Pro’s Simple UI, and is shown as such in Lux-Perpetua’s diagram.
Secondly, if you’re worried about Simple UI having a 150/150 ceiling, then perhaps the SP10 Pro isn’t for you. But I don’t think there’s anything dangerous about it. No one is getting burnt from an SP10. It has no higher output than the stock SP10S that Sofirn has now been selling for years. If anything, it is now safer since it will have thermal regulation.
Maybe L-P can copy those graphs to the OP. These are very informative, and 36 pages is like impossible to go through.
got it, youre right, I misunderstood
youre right again,
I keep thinking the SP10 will have the same 150/150 of 1200 lumens on LiIon, like the FWAA
youve reminded me we covered this before,
and I concluded the Eneloop option in the SP10 PRO will eliminate any Fear of Turbo…
