Convoy S21A (Short Technical Review)
Is the SST40 of this review the 5000K version ? It seems like by the picture
Just got mine in, does anyone know of a clip that fits around the light and is captured by the tailcap?
In this style…
Click
It's the 6500K version
The Convoy S21A can be had with either the “4 modes” driver or the “12 groups” driver.
Link:
https://www.aliexpress.com/item/33026858558.html?pdp_ext_f={"sku_id":"10000012685260820","ship_from":""}&gps-id=pcStoreJustForYou&scm=1007.23125.137358.0&scm_id=1007.23125.137358.0&scm-url=1007.23125.137358.0&pvid=fbf2855a-361a-42fb-9ce1-6b7f0d8ee00c&spm=a2g0o.store_pc_home.smartJustForYou_650637087.0
In the “12 groups” driver instruction it is mentioned: “BTW, do not leave the light in config mode for long period of time, because it will wear out the driver’s memory faster.”
Does that mean that Convoy lights with the “4 modes” driver will last longer than those with “12 groups” driver ?
Thank you in advance.
Probably best asking in a thread that Convoy owner Simon posts in regularly about the driver ‘wearing out’.
yes, IF you plan on leaving the light in config mode… !
If you use it like a light and reconfigure it only occasionally I cant see you being able to see any meaningful difference in driver life
Cheers everyone!
Does anyone know what kind of thread is used in the tailcap to hold the switch in place? For a modification project I need to 3D print a part with the same thread. I’m from Europe so I’m not familiar with threads outside of metric threads. My closest guess would be ANSI 3/4-28 UN right now? Unfortunately, a test printed ANSI 3/4-28 UN created with Fusion 360 did not fit.
Thank you, Jan
No ideas?
I almost responded, but the info in my mind was for a emisar light.
I’ll be checking the s21 in a minute here at work
Edit: ok… .743 od on the brass ring. Kind close to 19mm if you ask me.
Also with my old eyes, it appears to be about .75mm pitch
And it’s left handed as well.
Start with that, 19mm x .75 pitch, LH.
I don’t know what’s common for metric, as .7mm pitch is also close
To my knowledge M19 isn’t a common thread size - so Fusion360 doesn’t have a M19 thread option out of the box - and that’s why I’ve been looking for 3/4” non metric threads instead. But you are right, if (!) it’s a metric thread, it would be M19 x 0,75.
@ Freeriderz:
I don’t have such with me (S21A) but from justanotherguy if it has .75mm pitch (eyeballing it), I be looking at 3/4” x 32 TPI Left Hand. That’s closer to .75mm than 28 TPI.
BTW, all 24 or 32 TPI are standard on inch stock bar. But a better way to check pitch is against a known screw. Doesn’t matter the size, just if the threads mesh*. OD of threaded part is always some .005 to .008” less than nominal (sometimes much more for sloppy fit).
EDIT: * Oops – Left-hand thread can’t mesh stock screws (right hand). But check if crests line up.
Thank you Sidney! I’m going to give “3/4” × 32 TPI” a shot! Might have to buy a new and smaller nozzle though. I’ll keep you posted!
Could check with standard #6, #8, or #10 screw (these are 32TPI) and aligning up the crests. Might need a magnifier to get into the tight spaces.
Geez, my bad. You’re in Germany so those screws wouldn’t be readily available. Perhaps from some US made item, just provisional borrowing.
Addendum:
Don’t mean to be condescent, but a set of screw pitch gages saves the day (Link to Ali Ex). Machinist by trade and had a few surprises with some of the in-house threads – flashlights and other things. Also a digital caliper is essential in measurement (link Ali Ex ).
Can anybody advise what quad/triple Optics fits into S21A?
Preferably from Carclo or Ledil.
AFAIR there’s 23,2mm glass (or so).
S21C with triple lens
S21D with quad lens
they will be available soon
Kaidomain quad led + optics
Wooow, brilliant. How long (approximately)?
S21D available now
Awesome, already in my cart. Is it possible to buy spare quad lens?
It’s not expensive, if you need one ,i can add one for free ,pls note this in the remarks
