Trouble with a convoy s11
7 posts / 0 new
Thom986
Thom986's picture
Last seen: 2 months 6 days ago
I buy a Convoy S11 GT FC40 with battery on Simon store on Alie.
https://fr.aliexpress.com/item/1005002670364489.html?spm=a2g0s.9042311.0...
I have a problem when the lamp is at full power at 100% : Every 4/5 seconds it goes out and comes back on half a second later. I hear a little noise, a click each time it happens.
I tried to make a small video to illustrate my problem : https://www.youtube.com/watch?v=G6NIQA1sqHk
If anyone has any advice, I’m interested.
Thanks.
(ps: I am not bilingual, I use deepl.)
Quadrupel
Quadrupel's picture
Last seen: 1 hour 38 min ago
…a click each time…. so dont push the button !?
Thom986
Thom986's picture
Nop, I don’t click at all. Big Smile
Haukkeli
Last seen: 4 min 40 sec ago
Sounds like low voltage warning. In mine it happened because of insufficient grounding. I cleaned all the contact surfaces with electric cleaner and that fixed it.
Thom986
Thom986's picture
Thanks for the reply. It’s seemed not to work.
I’m talking with Simon but I’m no fluent and I have difficulty to translate :
Does it work normally, if you use the keep power battery?
Can someone explained to my what does it mean ?
Thanks.
mattlward
mattlward's picture
Last seen: 7 min 16 sec ago
Depending upon the protection circuit in that battery, it may not be able to deliver enough current to run the light. The protection circuit will shut down the battery output and reset after a bit… I think it resets, does not require a charger to reset.
In all of my FC40 lights I run unprotected cells to avoid this. Just like the little FWAA will trip protection on a 3 amp Xtar cell, put the wrong cell in a couple of times and it happens as soon as you get near high on the ramp.
If you do not have a good protected cell in 26650, like the older Lii or Kong cells, try with a 21700 cell. It not fit great, but will work for testing. I have little adapter tubes to use 18650 cells in 21700 and 26650 lights, they work great and you can get into some seriously good 18650’s that way.
EDC rotation:
FW1A, LH351D 4000k (second favorite)
FW3A, LH351D 3500k
FW3A, SST20 FD2 4000k
FW3A, Nichia 4000k sw40 r9080 (favorite light!)
FW3A, Cree XP-L Hi 5A3
Emisar D4V2, SST20 4000k
mortuus
mortuus's picture
Last seen: 9 hours 19 min ago
are u using a non protected battery? maybe the protected is too weak..
...where Frugal meets with Flashlight!
              つ ◕_◕ ༽つ
