FastTech New Arrivals & Promotion
Nitecore P20i UV LED Flashlight
1*Luminus SST-40-W LED + 4*365nm LED / 5-mode / 1800LM / pure white & UV light / 1*21700/2*CR123 / IP68 waterproof
Head diameter: 31.8mm
Tail diameter: 28.5mm
Nitecore P20iX Tactical LED Flashlight
4*Cree XP-L2 V6 LED / 7-mode / 4000LM / pure white / 1*21700/2*CR123 / IP68 waterproof (2m underwater)
Nitecore P10iX Tactical LED Flashlight
Head diameter: 28.5mm
Tail diameter: 25.4mm
Thanks, what is the the sitewide promotion for Labor Day?
I am sorry that the sitewide promotion for Labor Day was canceled temporary, since another sitewide promotion is coming recently. Please don’t worry, we will have a sitewide promotion soon. Please pay attention to the update and notification on our website.
Take advantage of Labor Day sale and save up to 18%
1*LED 6-Mode 2200LM Tactical LED Flashlight w/ Focus Zoom
pure white / IPX4 waterproof / clip / OLED display
  • Head diameter: 44mm
  • Tail diameter: 35mm
  • Smart screen displays mode, lumens, voltage and power
  • Operation:
    Press and hold for three seconds and then turn on the flashlight, display WELCOME, then enter L1 mode (200LM), click again to enter L2 mode (500LM)
    Click again to enter L3 mode (1200LM), click again to enter L4 mode (STR flashes), click again to return to L1 mode
    Quickly double-click to enter H mode (2200LM super bright mode), click in this mode to enter SOS mode, and click again to return to H mode
    Long press for three seconds to turn off, the screen displays GOODBYE
1*LED 3-Mode 2500LM LED Flashlight w/ Focus Zoom
pure white / IPX4 waterproof / window breaker / power display
Head diameter: 60mm
Tail diameter: 33mm
The design of the extension tube of the flashlight can be switched between long and short models.
Niwalker ETmini V2 EDC LED Flashlight
1*OSRAM PUSRA1.PM (3W) LED+3*OSRAM PUSRA1.PM (2W) LED / 2350LM / 3000K & 6000K / IPX7 / USB-C rechargeable
  • LED Source: 1pc OSRAM PUSRA1.PM (3W) LED & 3pcs OSRAM PUSRA1.PM (2W) LED
  • Output: Max 3050 Lumens with Turbo
    3*LED 6000K (CW): 2350 Lumens
    1*LED 3000K (NW): 1100 Lumens respectively
  • Intensity: 8380cd with medium brightness
  • Beam distance: 183 Meter with medium brightness
  • Switch: Side control Switch with LED indicator to monitor battery level
  • Charging Port: Type-C Fast charging
  • Battery: One high drain and unprotected 18350/20350 cell (not included)
  • User interfaces: Press side switch to on/off. Hold the switch after on, smooth ramping will be able to switch the brightness from low to high and high to low. Ability to toggle between Smooth and Stepped ramping. Double clicks will get instant access for turbo mode.
  • Other functions/modes: Timing mode, Flash alternative mode, Power monitoring, Firefly mode, Single or dual head mode. (pls refer to user manual for more exciting modes)
  • Lockout: Yes, clicks 4 times to lock and unlock
  • Memory: Yes. Will memorize the last brightness mode
  • Optic: Standard TIR Optic Lens for 3*LEDs Lens and Orange Peel reflector for 1*LED Lens
  • Body: Aluminum with hard Finishing
  • Magnetic Tailcap: Yes, hands free while work
  • Waterproof: IPX7 1m underwater for 30min max
Purchase our gift card and get an extra 3% free value automatically
Nitecore TM06S LED Flashlight
4*Cree XM-L2 U3 LED / 8-mode / 4000LM / pure white / 4*18650 / IPX8 waterproof (2m underwater)
Nitecore BR25 Bicycle LED Front Light
1*Luminus SST-40-W LED / 5-mode / 1400LM / pure white / 1*21700/1*18650/2*CR123/2*RCR123 / IP68 waterproof
Happy Chinese Mid-Autumn Festival | Sitewide 7% OFF & 3% Gift Certificate Extra Amount
New Arrival OLIGHT MARAUDER 2 LED Flashlight Set
12*OSRAM P9+1*OSRAM PM1 / 15-mode / 14000LM / pure white / 3*21700 / USB-C rechargeable / US / 800m spotlight beam / power bank function
Extremely Powerful and Flexible: Featuring an 800-meter spotlight beam from the central LED, and a 14000-lumen floodlight beam from 12 surrounding LEDs. Built-in 54Wh rechargeable lithium-ion battery pack (three 5000mAh 21700 batteries), ensuring up to 59 hours of runtime.
Double Button Cooperative Power: A simple toggle switch to select either spotlight or floodlight; an intuitive rotary knob switch to turn on the light and circle through 7 output levels. (Note: Rotate the knob switch quickly over 90 degrees to unlock it.)
Equipped With Powerful Power Supply: Capable of 30W charging and 30W reverse charging. Only take 2.5 hours to fully charge. Able to charge a phone, a pad, or any device that uses a USB Type C power source.
Durable Quality and Unique Design: The aperture-blade-style port cover can be opened and closed by twisting the tail cap, IPX8 (2m), Drop Test: 1m. Silicone surface for a solid grip; hidden lanyard hole for portability; indicators to reveal brightness level, battery level, and charging status.
With intelligent temperature control
The head has a built-in light sensor, if it is blocked by an object, it will automatically reduce the brightness to ensure safe use
Compatible charging protocol: QC2.0, QC3.0, PD2.0, PD 3.0, APPLE, DCP, AFC
Charging voltage/current: 5V3A, 9V3A, 12V2.5A, 15V2A, 20V1.5A
Reverse charging voltage and current: 5V3A, 9V3A, 12V2.5A, 15V2A, 20V1.5A
Please note:
When used as a mobile power source, the flashlight can only charge one device at a time. It is prohibited to use any multi-port USB hub to charge other devices or to use two or more devices at the same time.
Do not shine the light directly on the eyes, it may cause temporary blindness or permanent damage to the eyes
CYANSKY K3 LED Flashlight
1*Luminnus SST40 HI / 5-mode / 2000LM / pure white / 600m beam range / 1*21700/1*18650 / clilp / lanyard / IPX8 waterproof
Head diameter: 40mm
Voltage: 3.7-4.2V
Applicable temperature: –30’C~50’C
2m impact resistance
EAGLE EYE X6R LED Flashlight
1-LED / 1-mode / 350LM / 1*18650 / clip & lanyard
Reflector diameter: 32mm
Head diameter: 39mm
Tube diameter: 25mm
Tail diameter: 25mm
Lanyard length: 27cm
Beam range: 200-500 meters
Working voltage: 3.7V
CYANSKY HS6R Triple Output LED Headlamp
1*Luminus SST-40+2*Luminus SST-20-W LED / 9-mode / 1400LM / white & red light / 1*18650/2*CR123A / USB-C
Lumens: Spotlight (white main light): 50-1200LM; Floodlight (white auxiliary light): 50-500LM; Both of spotlight and floodlight synchronously turns on: 1400LM
Up and down 90 degrees rotation
Hi,
I just did a review of this here: https://www.youtube.com/watch?v=\_p85AaTEVfI&ab_channel=ThrowHound
But the listed specs are all wrong. It’s not “1-mode” or “350 lumens.” Please correct…it is SST-40, 1400 lumens, 495 meters beam distance, and 4-modes. This is one of the all-time best lights ever made!
Limited Clearance! Save up to 90%! 400+PCS from USD $1.99! Don’t hesitate! Shop Now→
Sofirn C01S 100LM 4000K Keychain LED Flashlight
1*Luminus SST20 LED / 2-mode / 1*AAA / IPX8 / 42m beam distance
C01S is a tiny Keychain light that is upgraded from BLF C01. With 2 modes and update to 100lm output. It is designed for finding keys, reading, EDC and emergency, etc. It can be operated from a single AAA battery (Alkaline/ Ni-MH). Rotate head to turn on / off.
Features:
Compact size more portability
Case Material is 6061 aircraft-grade aluminum,hard-anodized anti-abrasive finish, and better heat exchange
Stability, heat resistance, cold resistance, anti-fall, anti-pressure
Specification:
Head diameter: 14.5mmCRI (min): 95
Working Voltage: 0.9V-1.5V
Battery Options: One 1.5V AAA Alkaline battery or one 1.2V Ni-MH battery (Neither Included)
Flashlight body: Aerospace graded 6061 aluminum alloy, CNC manufactured to hard-anodized anti-abrasive finish to get the solidly built body, anti-crash geometry, and better heat exchange.
DIY Enabled: the tail cap stands upside down; the round hole is for a 5mm (diameter) magnet, and the other is a trit hole (magnet and trit not included)
Operation Instruction:
When OFF, screw down the battery case to turn on and modes from low-high; unscrew the battery case to turn off.
When On, unscrew the battery case to turn off and then rapidly screw down the battery case to change the mode; no memory function and default brightness is Low mode.
