Are 219B R9080 emitters inherently inefficient compared to more recently produced emitters? What’s the closest to tint temperature that you can get to a 219B R9080 sw40 or sw45 using a more efficient emitter or similar die size?
They actually aren’t terribly inefficient relatively speaking to say an SST20w. They just lack overdriving capabilities. At their ‘sweet spot’ max current in D220 bin, which I peg around 2.75-3A they are doing about 68lm/W. An SST20w in J4 bin (J5 can be had easily these days) at the same current is doing about 75 lm/W. So about a 10% hit. They fall on their face much past 3A though, while SST20w chugs out to 6.75A before the bond wires pop.
I thought we had 3v emitters giving close to 150 lumen /w today. See! Wee need a chart!
If you’re comparing Texas Ace (219B) and maukka (sst20) numbers, on the one LED they both tested (E21A) TA was 7~8% above IIRC so that 219B number might be a bit overestimated. Plus the sst20 is 500K less.
What’s the die size on the SST-20 ? Might be a bit smaller, although the 219b is quite small already.
One other thing to consider is that less green makes the LED less efficient, so it’s difficult to compare sw45k. Non k bins would be better to compare to but they haven’t been tested.
SBT 90.2 for big lights and Nichia 219b for small lights.
I was using those two datasets as reference. I didn’t realize TAs numbers were that much higher… I have tested multiple SST20s and my results line up with maukkas very well. I’m ordering some 219Bs from Simon and will test those in the future apples to apples.
Effective die size on the SST20 is 1.75mm² according to my spreadsheet. Natively it’s 2mm², but the bond wire pads block some. I have some sliced 219Bs in my stash I could measure later but I’m fairly certain it’s just under 2mm² from memory. Nothing recorded in my notes. I’m getting about 1.5mm * 1.5mm so 2.25mm²
Also, my thoughts on use of 219B is as follows. If per emitter current is below ~2A the majority of the time (aka triples quads etc) and especially if there is a buck or boost (for AA lights) driver then I’ll take it over SST20 all day. By the time you tint correct or pwm a FET on the SST20, efficacy is at or below a 219B.
SST20w is a throw king though and wins out in single emitter lights with anything larger than 1*14500
Yeah they got the same area here for the 219B : LED Package/ Die Sizes - WIP -
Personnaly I like sliced 90CRI LH351D, especially 3500K : virtually no angle tint shift, neutral tint/slightly under the BBL at low/high output, R9 close to 80, while keeping a higher efficiency than an SST-20.
Also B35AM 9080 : neutral/slightly rosy at low/high current, virtually no angle tint shift, very high CRI, higher power 3535 sized LED.
For the 219B I would prefer a sw40k or sw35k since I prefer warmer CCTs, still like the sw45k though.
Favorite emitter? That’s a tough one. Either the 219B or E17A. Currently it’s the quad E17As.
Sliced and diced XHP70.2 at 12volts, 8amps, 8500 lumens.
MT-G2 4000K was a good one for a long time —- I’m liking LH351D 3500k I bought from some one on BLF
One that works. Having anything else is rather pointless
219B 4500K (sw45k) all day everyday. Most of my lights are of the EDC variety so it fits the bill.
Was SST40 6500K & LH351D 5000K. Now that I’m all grown-up,
It’s SFT40 for stompin around & 219b obsession!!
I’m sure in a year from now it’ll be different.
Oh man, this is a great thread question! I haven't been around long enough to know obscure awesome leds like many folks here, but I have a couple I really like, and I also have my first sw35 and sw30 219b's coming in on order from Simon, so I can't say either of those yet though I'm hoping the sw30 makes it to the top of the list, especially since I wasn't overly impressed with the sw45k from emisar (I just like warmer tints too much and it felt too cool was all really, the color was nice of course).
- xpl-hi 5D (the rosy one from emisar 8 months ago when he did NOT have them in stock or as an option on his site but still had them in his store and sent me a KR4 with them and they are perfect - rosy, bright and awesome, thought a little more like 4200k).
- xhp35 HI 4000k (like in my skilhunt from mbplitt and/or id30209 :), or my k1 from Noctigon- perfect)
- osram CULPM1 (bright, throws very well, and nice tint for a throwing led)
- sbt90.2 (just impressive in every way, including a decent tint)
- sft40 (just, wow. And coming out in 5000k?! Awesome)
- xpl-hi 2850k 8A (rosy, bright, nice tint and decent cri. It's a great all-arounder)
I have my first gt fc40 light coming in, so that is HIGHLY anticipated as well as the sw30 219b. I have a feeling one of or both of them may be on this list.
Naw, the TIP31. Twice the fun…
Oh yeh, the MT-G2. Creamy white goodness…
This one in my D4V1
XP G2 S4 3D 4885
yes, yes, and I need one of those sc600 HI ! Lol. Will ZL ever release them again?
I also always liked the old MT-G2. I think all of mine were 5000k. Great tint.
219b is a classic. My current favorite all around is LH351D 3500k or 4000k.
My favorite for power include SBT90.2 and W2 for power! Favorite host for each are the GT94vn and D4SV2.
For CRI the 219B Nichia sw35 and sw45k; and GT-FC40 A4 4500k. The host each are SC64c and D4v2; and the rainbow titanium E70 for the Getian.
Thanks. That’s encouraging to know. Maybe at some point down the road, we’ll have enough of this info culminated into a chart of some kind. Would be great to understand the relative characteristics of emitters across the gamut, their features and limitations.
