I always like the xpg-g2. Perfect throw and hotspot. What’s your favorite emitter?
I’m partial to the xhp70.2, SST40, and sst70.
The one in the 2N3055. Ok I’m showing my age.
My choice of favorite emitter evolves as newer emitters are released. Currently, SBT90.2.
I also like XHP70.2 and Osram W2. Different emitters are best for small, medium and large size throwers, power throwers and flooders.
XP-L2 HD, good do most everything LED.
Is there any collection of the different emitters powerdraw at a specific lumen and or candela? Would be nice to have a cheatsheet.
depends on application
lights for primarily outdoors:
LH351D 5000k 90CRI (the d0gfarts one
quite efficient in lm/W, so it has good throw
large hotspot, so useful for close range too
colors and tint are very good
lights for indoors / small close-range EDC:
second pick would be 219B 4500k 9050
ultra-perfect colors and tint
but efficiency is abysmal
wish SST20 in 5000k/5600k was 95CRI, the 4000K one has really nice colors but it’s a bit too yellow, especially on low current
SBT90.2 is awesome.
But I also like the sst70 and sst40. And I like my only light with sft40, so I’m sure I’d like the sft70…gotta get one of those!
95CRI SFT40… oh wait… ![]()
There is a spreadsheet somewhere, I forget where. But I believe there is a thread linking to it. If I find it I’ll update.
It always seems to be the one I don’t have
Are 219B R9080 emitters inherently inefficient compared to more recently produced emitters? What’s the closest to tint temperature that you can get to a 219B R9080 sw40 or sw45 using a more efficient emitter or similar die size?
They actually aren’t terribly inefficient relatively speaking to say an SST20w. They just lack overdriving capabilities. At their ‘sweet spot’ max current in D220 bin, which I peg around 2.75-3A they are doing about 68lm/W. An SST20w in J4 bin (J5 can be had easily these days) at the same current is doing about 75 lm/W. So about a 10% hit. They fall on their face much past 3A though, while SST20w chugs out to 6.75A before the bond wires pop.
I thought we had 3v emitters giving close to 150 lumen /w today. See! Wee need a chart! ![]()
If you’re comparing Texas Ace (219B) and maukka (sst20) numbers, on the one LED they both tested (E21A) TA was 7~8% above IIRC so that 219B number might be a bit overestimated. Plus the sst20 is 500K less.
What’s the die size on the SST-20 ? Might be a bit smaller, although the 219b is quite small already.
One other thing to consider is that less green makes the LED less efficient, so it’s difficult to compare sw45k. Non k bins would be better to compare to but they haven’t been tested.
SBT 90.2 for big lights and Nichia 219b for small lights.
I was using those two datasets as reference. I didn’t realize TAs numbers were that much higher… I have tested multiple SST20s and my results line up with maukkas very well. I’m ordering some 219Bs from Simon and will test those in the future apples to apples.
Effective die size on the SST20 is 1.75mm² according to my spreadsheet. Natively it’s 2mm², but the bond wire pads block some. I have some sliced 219Bs in my stash I could measure later but I’m fairly certain it’s just under 2mm² from memory. Nothing recorded in my notes. I’m getting about 1.5mm * 1.5mm so 2.25mm²
Also, my thoughts on use of 219B is as follows. If per emitter current is below ~2A the majority of the time (aka triples quads etc) and especially if there is a buck or boost (for AA lights) driver then I’ll take it over SST20 all day. By the time you tint correct or pwm a FET on the SST20, efficacy is at or below a 219B.
SST20w is a throw king though and wins out in single emitter lights with anything larger than 1*14500
Yeah they got the same area here for the 219B : LED Package/ Die Sizes - WIP -
Personnaly I like sliced 90CRI LH351D, especially 3500K : virtually no angle tint shift, neutral tint/slightly under the BBL at low/high output, R9 close to 80, while keeping a higher efficiency than an SST-20.
Also B35AM 9080 : neutral/slightly rosy at low/high current, virtually no angle tint shift, very high CRI, higher power 3535 sized LED.
For the 219B I would prefer a sw40k or sw35k since I prefer warmer CCTs, still like the sw45k though.
Favorite emitter? That’s a tough one. Either the 219B or E17A. Currently it’s the quad E17As.
Sliced and diced XHP70.2 at 12volts, 8amps, 8500 lumens.
