The code is work on new anduril 2.0 version LT1----1MY7001VGT2Y, old version nope
New 2.0 LINK:
New 2.0 LINK:
IF22A/IF22 restock , order now with discount price and could use code :5XD4VLM0HKFP
HS05 New discount link, with more tint for choice: 2700K. 4000K, 5000K
https://www.aliexpress.com/item/1005003238479405.html?spm=a2g0s.12269583.0.0.7739d665dOnOIN
It’s only a sample batch, the final release will be an SFT40 to replace the XHP50.2.
The massive issue is the weight. I was told it’s roughly 300g
about 170gram with battery inside and headband
HD05 code update 20%- VYPE5NGDQDI7
SC21 code 9KFOP8NSVHR3 15%
Funtastic: Quadrupel:Waiting for HS20 review and teardown and don’t understand which side is for throw which is for flood? It define messed up. It can be nice host for modding but not in this price range . :person_facepalming:
It’s only a sample batch, the final release will be an SFT40 to replace the XHP50.2. The massive issue is the weight. I was told it’s roughly 300g
Well that’s a relief! Thank you
HS05 code update 20%- VYPE5NGDQDI7 4000k, 5000k available now
When will 2700k be in stock?
Jackie:HS05 code update 20%- VYPE5NGDQDI7 4000k, 5000k available now
will wait next batch about 15-20 days, no more host to be assemble to 2700K now,
SC21 new link with more color tint for choice, 2700k, 4000k, 5000k:
20% code valid --VYPE5NGDQDI7
Jackie, any chance of an HS01 or whatever you want to call it? Like HS05 but smaller, using AAA instead of AA and with a narrower headband and maybe a tiny carrying pouch. There are so few headlamps in that format. Even a C01S in right angle style would be great.
Hello Jackie, is the discount code still valid? I have just try it but not working. Thanks!
Jackie:IF22A/IF22 restock , order now with discount price and could use code :5XD4VLM0HKFP
Yes, new code update :LN6GAFDHYAFC
unlimited spend value code $2---EAOPYQ9WSMTX for all models on weekend
New model release sofirn SP10V3.0---1000lm high CRI 14500 Mini light
CODE :LN6GAFDHYAFC
would love to try new sliver color if IF22A? go link to:https://www.aliexpress.com/item/1005003349281393.html?spm=5261.ProductManageOnline.0.0.1c394edfiG4TCz
Code 10% OFF---LN6GAFDHYAFC
SILIVER
I think Sofirn looks great in silver and then I wouldn’t have to use drain cleaner!
