Now could update it successfully the TC66C to firmware 1.15. What happened had the Windows software installed to ‘C:\Program Files (x86)\RuiDengUSBMeter\RuiDengUSBMeter.exe’, which requires administrative permissions to run from there. After enabling the .exe to run as administrator now works perfect: 固件升级完成,等待设备有自
Yeah you can, but the output will be most likely fixed at 5V, and depending on the cable it may or may not transmit the power to the other end, some USB-C cable requires authentication before allowing power transfer.
Regarding the POWER-Z FL001 SUPER, is there any way to force the meter to start in English? As is, every time I plug it in I have to change the interface from Chinese to English, which is mildly annoying despite it not being that difficult.
Also, is there a firmware update that offers support for Apple’s charging protocols?
*For anyone searching for information on changing the language: double-click the large rocker-style switch, then double-click it again. English! (Unless you accidentally single clicked it the second time. In which case, enjoy your newly rotated display. In Mandarin.)
Have problems with the TC66C app, on Samsung with Android 12: says “Storage permissions are not open” and “Storage error” whenever I click on SHARE.
Anybody else having the same issue with Android 12, Samsung or not?
TheHWcave has some great in depth looks and testing of various USB meters. i learned a bunch about my UNI-T UT658 USB testers play list
i don’t know why he has so few subscribers? i think he’s fantastic.
ChargerLAB is the US / English brand with English site and links to Amazon US.
The Chinese brand is Power-Z. They have a separate website: https://www.power-z.cn/ The Power-Z site has links to various online Asian suppliers & market places as well as back to Amazon US.
I am looking at purchasing the Chargelab Power-Z KM-003c myself. They have a YouTube channel so you can see it in action. ChargerLab YouTube Chanel
I can recommend the AVHzY brand. I have the C3 Type-C tester and works very well. I have converted almost everything to USB-C so therefore
I bought the USB-C tester. It has pretty good PC software that you connect via USB-C.
I’m also looking at Witen. But their newest tester (C4) seems to be in beta form still therefore I am waiting. But it also looks fantastic.
I also own the YZXStudio ZY1276 and a couple cheap Keweisi KW-1902c and the KWS-MX18L. The cheaper ones are very basic, but might be all you need.
Check them all out and compare to see which one is best for your needs.
