OK, so i just read thru the las page. Im going to remove the head and tail retaining ring, clean with alcohol, center the driver if needed, and reassemble. Ill try it tomorrow and see if it works better. I have owned 6 of these with no issues whatsoever. So Ii feel confident it will be resolved. and, if not, Lume driver from Neal it is!
Try slightly loosening the tailcap retaining ring. If the switchboard is slightly loose it can float. This may give a better connection than if screwed all the way down
You were 100% right. I loosed the tail cap retaining ring a little and its working.
Other things i did - I 'popped' out the inner tube (it doesn't free float like the KR4 does) and reinserted it. I also did NOT tighten everything down Extremely tight. I checked out a couple of my other fw3a's that work perfectly and noticed none of them are wrenched down ungodly tight, so i just tightened everything with medium/tight pressure, now the new fw3a that had the problem is working Perfectly.
Hi Artie T59, I just read about your experience fixing your FW3A.
I bought one FW3A from Neals Gadgets during the recent Father’s Day Sale, together with a SS bezel, a sapphire lens, clip, and (my big mistake…. an 18350 tube).
I did note that there is a “warning” not to open the tail cap. I was OK with that for several weeks, enjoying the FW3A as my EDC. But finally I decided to try changing the long tube into the 18350. And that was when I messed up the tail-cap switch. It fell apart, some parts are loose. It doesn’t click, and doesn’t turn on the flashlight.
I tried to put back the 18650 tube. But the switch doesn’t work any more.
I sent an e-mail to Neals to his Hotmail a few days ago; but he has not responded.
I want to find out whether Neals’ shop sells a replacement tail-cap switch for FW3A (?)
I have seen some Youtube videos about people inserting some colourful glow rubber part into the tail-cap switch. They look simple, but I just don’t have any tools to tighten the parts. Hence my question whether I can buy any replacement tail-cap switch anywhere.
Did you loose the little black nub that presses the switch? If not, you should be able to put it back together. If so, you can make a new nub with some plastic.
hey buddy, so I have seen members on Reddit recently with glow switches and all of that for the Fw3a, so I think they are still around (I think neal has a couple colors left actually), but from what it sounds alike that may not be your problem.
So when you started having the issue with the switch, did the switch come apart by any chance? Or was it just loose? I only ask because there is a very small piece of plastic in the switch that allows it to engage. People refer to To it as a nubbin. Anyway, if it is not in there, or if the switch was so loose that it become dislodged from its seating, then the switch won't work.
the good news- the only tool you need to work in the switch is a small needle nose plyer or even two small screwdrivers or even two small nails. Just something to put into the small holes in the retaining ring to loosen and tighten it. The switch design once you open it up is very simple and straight forward. And there is good info and pictures and even YouTube videos showing how to dissemble and reassemble the switch.
Thanks Jason WW and Artie T59 for your quick kind advice. Will look for that small plastic part. I don’t recall seeing it when I tried to push and press the switch back in shape.
I think what is happening is that if the tailcap retaining ring is screwed down too tightly it is at a very slight angle to the top of the inner tube. This creates a very poor switch connection. If the retaining ring is left loose, the tailcap board floats slightly and can then press flat against the edge of the inner tube creating a good connection.
I first noticed this when I had problems with switch connection on a later model FW3A with the switch retaining ring tightly screwed down while the problem did not occur at all on an early model with no switch retaining ring. Slightly loosening the switch retaining ring solved the problem.
The “nubbin” is a tiny black plastic cylinder that sockets into the center of the rubber switch boot. It can get lost easily and the switch will not work without it (without modification).
Unfortunately, it’s likely that part is lost for good. The part is miniscule and due to its shape prone to rolling a long distance if dropped.
Fortunately, the nubbin isn’t required. Some options:
Make a new nubbin - A bit of cured epoxy putty cut into the general shape of the nubbin with an x-acto knife works. Even a piece of a toothpick would probably work; or
Skip the nubbin, do the o-ring mod instead - The FW3A’s switch is very soft and easy to accidentally depress in the pocket. A popular mod with the FW3A is to remove the nubbin and add an o-ring inside the switch boot. The o-ring should be wide enough to fit in the depression in the rubber boot outside the nubbin-socket. I am big fan of the o-ring mod. I’ve done it to all my FW3 series lights.
No o-ring? … no problem - a bent piece of wire bent into a ring should work. As long as it is approximately the right thickness. Some experimentation might be required.
I had installed an 18350 tube on my FW3A. I was having unwanted activation problems. The emitter would immediately turn on and start ramping up or start on high and ramp down. No control.
While trying to troubleshoot this, I had figured the tail cap and head weren’t tightened down enough onto the body. As I cranked it with the head off, my forefinger had pressed down on the screw threads. They are seriously sharp. Cut right into my skin, drawing blood. This is really unforgivable. These threads should be squared off. Nasty… just nasty.
The behavior your getting is that of a shorted switch circuit. Unscrew the head and do a continuity check between the inner tube end and the body. It should not be connected unless the button is pressed.
If it checks out, then the new body might be screwing down onto the ring trace on the driver that the inner tube touches. Make sure the driver is centered.
Any body ever figure out how to solve —- No matter where you set the ceiling of the ramp and no matter how you set the temperature —- I always get a ramp down to around 300 lumens ( the Light is Cold ) — then it will gradually work its way back up to 600 lumens—- After it does this little dance you can go to the top of the ramp and the thermal calibration works fine —— I have several of these lights that do this crap — the only one that doesn’t do it — The Original XPL version from the First Batch
I think this is just how the temperature regulation is programmed in the version of Anduril used in the FW3A. If you want to avoid this behavior, you’ll need different firmware with better programming of the temperature regulation.
If you are interested in flashing to better firmware, Check with Toykeeper. Later versions of Anduril or Anduril 2 may have better regulation. I quite like my Emisar D4V2 variable tint which lacks the fast rampdown behavior of my earlier Anduril lights.
