Sofirn Q8 Pro Comprehensive Review
32 posts / 0 new
pol77
Last seen: 1 day 17 hours ago
Hello fellow BLFers. I have published a comprehensive review of the Sofirn Q8 Pro. I was quite surprised as this is the first Sofirn torch I reviewed to actually measure well over its specs! Please let me know what you think.
The review can be found here: https://www.thelab.gr/reviews/reviews-in-english/sofirn-q8-pro-r810/
A 30% discount code for Amazon UK is included!
Edited by: pol77 on 10/01/2021 - 05:50
stephenk
stephenk's picture
Last seen: 6 hours 12 min ago
Thanks for the comprehensive review. I was expecting better sustained brightness, as it appears to be outclassed by the single battery Convoy M21D XHP70.2.
TermsakC
TermsakC's picture
Last seen: 51 min 50 sec ago
Thanks pol77 for sharing the very informative review. This is the first one I have seen on the Sofirn Q8Pro.
Still undecided on whether I will buy one. A good opportunity to buy with a good discount will arrive on 10 October — the 10/10 Sale! Cash
But I already have the Sofirn Q8. So I am looking around for more reviews to learn more about the Q8Pro. Smile
Sofirn
Sofirn's picture
Last seen: 1 hour 18 min ago
Q8 Pro wall beamshot pictures, Left side is 6000-6500K. The light is cooler. While the right side is 5000-5300K and the light is more neutral. Which one do you like better? Is the difference between these two as big as you thought?
Click to Check
Click to Check
PM me to get coupon code innocent
Sirstinky
Last seen: 5 hours 41 min ago
6500k vs 5300k is a big difference. The xhp50.2 is not known for good tint uniformity or beam quality. OP reflector help with that, but it’s hard to fet rid of it.
Unheard
Unheard's picture
Last seen: 12 hours 41 min ago
Sofirn, do you have a sufficient stock of the XHP50.2/5000K to sell on sofirnlight.com? Do you participate in IOSS?
Spitzbube.
stephenk
stephenk's picture
Good to see a neutral white Q8 Pro!
Tangra
Last seen: 5 months 1 day ago
Good to see new driver.
d_t_a
Last seen: 1 hour 34 min ago
Nice comprehensive review.
I'll add some of my info.
The unit you got/reviewed appears to be the most recent batch, with the OP reflector.
1) earlier batch of Q8 Pro comes with (board "Q8Pro-A-A0 20210122"):
  - Anduril 1 firmware (2020-03-18)
  - has smooth reflector,
  - can charge at QuickCharge 2.0 9v/12v
  - powerbank output function also supports QuickCharge 2.0/3.0 (protocol detection with my USB meter indicates the power bank output also supports PD3.0 but I don't have a better way to test Power Delivery feature
2) recent batch of Q8 Pro now comes with (board "Q8Pro-A-A1 20210520"):
  - Anduril 2 firmware (version 2021-06-06 model code 611)
  - now has orange-peel reflector (I'm not sure if it will have much effect though compared to the previous SMO reflector)
  - can only charge at 5v (up to 3A)
  - powerbank out function also only outputs 5v (up to 3A), protocol detection with my USB meter indicates it supports DCP and Apple protocol (5v).
some other notes:
I believe the previous Sofirn 3000mAh 18650s use DLG batteries (no ring at the bottom)
The current Sofirn 3000mAh 18650 batteries seem to be BAK batteries (have ring at the bottom / negative side)
pol77
Thank you for the information d_t_a. I was not aware there was a previous batch with different characteristics. It is a pity they removed the QC and PD ability from the driver, it is something that would really add to the value of this product.
hcanning
Nice review. Looks like a great upgrade from the original Q8.
I made my own Q8 Pro last year, by asking Sofirn if they’d be so kind as to solder 4 × 3v XHP50.2s onto an appropriate MCPCB, and they obliged! I think I was the first person to ask them to do this, and it seemed to spur a few others to want to do it, and also for them to release it as a product.
I have done a few other mods such as spring bypasses, brass screws, Anduril flashing, AR glass, stripped anodisation, and changed the button LED colour. It’s one of a kind! I measured just under 17,000 lumens in my Maukka-calibrated lumen sphere. It’s an absolute weapon.
Notable lights: Q8 with 4 x 3V XHP50.2, bypassed springs, brass driver and tailcap screws, Anduril firmware, removed anodisation, AR glass, warm white switch LEDs (16,800lm)  |  Convoy S2+ with triple Luxeon V 4000k, Led4Power B4 Driver, Carclo 10507, bypassed springs (2900lm)  |   D18 in sand  |  D4V2 in sand  |  D4S in grey  |   FW3A with warm white XP-L HI  |   KR4 Mule in blue
Barry0892
Barry0892's picture
Last seen: 23 min 17 sec ago
Nice Review! comprehensive and informative Innocent
WhatsApp: +8615773183209
My new Facebook account: https://www.facebook.com/barry.dong.9250
jd13181
Last seen: 23 hours 40 min ago
Nice job on the review.
icpart
Last seen: 3 days 3 hours ago
I’ll add some of my info.
1) earlier batch of Q8 Pro comes with (board “Q8Pro-A-A0 20210122”):
  – Anduril 1 firmware (2020-03-18)
  – has smooth reflector,
  – can charge at QuickCharge 2.0 9v/12v
  – powerbank output function also supports QuickCharge 2.0/3.0 (protocol detection with my USB meter indicates the power bank output also supports PD3.0 but I don’t have a better way to test Power Delivery feature
2) recent batch of Q8 Pro now comes with (board “Q8Pro-A-A1 20210520”):
  – Anduril 2 firmware (version 2021-06-06 model code 611)
  – now has orange-peel reflector (I’m not sure if it will have much effect though compared to the previous SMO reflector)
  – can only charge at 5v (up to 3A)
  – powerbank out function also only outputs 5v (up to 3A), protocol detection with my USB meter indicates it supports DCP and Apple protocol (5v).
some other notes:
Seems in the new batch Sofirn downgrade the power bank function of Q8 Pro from PD to only to support ordinary USB fast charge.
Cigarguy
Last seen: 5 days 5 hours ago
Thanks for the review.
Got a couple of BLT LT1. Love that lantern and is pushing me to a Q8 as my next purchase.
texas shooter
Last seen: 1 hour 41 min ago
I’ve seen a few newer gadget down graded from previous builds. Is it cost cutting, design flaw or chip shortages? I tend to think the last two here.
EazyRyder
Last seen: 8 months 1 week ago
Great review on the Sofirn Q8 Pro.
Tried your 30% discount code on amazon UK. polymeros30 no longer works.
Do you have another 30% discount code?
Thank you.
Deano80
Got the Q8 pro and the If22a in my Amazon basket any 30% discount codes? Cheers Dean.
RoboEgg
Last seen: 1 day 16 hours ago
I have an original BLF Q8 and Sofirn Q8 Pro – It is a worthwhile upgrade for the additional power and efficiency of the xhp50s and the convenience of USB charging. Either way I recommend upgrading the firmware in your Q8 to Anduril 2 – you will love it – I do.
RoboEgg
Also latest batch only has single wires going to MCPCB.
Magnus.LPA
Magnus.LPA's picture
Last seen: 3 weeks 4 days ago
Hello everyone Smile
Long time reader here (years!) but new member Smile
It’s my first post and it is a question. I am not too proud about that ^^
There it goes:
I am the proud owner of many flashlights, diverse and all satisfying.
Recently, I bought a Q8 Pro as an upgrade to my original BLF Q8. The appeal of the USB charge, powerbank and blablabla you know the excuses we make to expand the collection.
However, 2 things have been frustrating me for the 48 hours I’ve had this light.
A. Can you change the color of the LED switch as indicated in the Anduril 2.0 manual?
The 7H from locked or standby doesn’t do anything for me.
B. How do you remove the reflector? I would like to swap it with the one in my original Q8 just for fun, but it seems glued to the head. I know it probably won’t even fit due to the difference in size between emitters, but I would love to try Smile
Can anyone help me with these questions?
Thank you.
pol77
Magnus.LPA wrote:
Hello everyone Smile Long time reader here (years!) but new member Smile It's my first post and it is a question. I am not too proud about that ^^ There it goes: I am the proud owner of many flashlights, diverse and all satisfying. Recently, I bought a Q8 Pro as an upgrade to my original BLF Q8. The appeal of the USB charge, powerbank and blablabla you know the excuses we make to expand the collection. However, 2 things have been frustrating me for the 48 hours I've had this light. A. Can you change the color of the LED switch as indicated in the Anduril 2.0 manual? The 7H from locked or standby doesn't do anything for me. B. How do you remove the reflector? I would like to swap it with the one in my original Q8 just for fun, but it seems glued to the head. I know it probably won't even fit due to the difference in size between emitters, but I would love to try Smile Can anyone help me with these questions? Thank you.
Hello, welcome and I hope I can help.
A. Anduril has the ability to control RGB Auxiliary and / or switch LEDs, if they are present. The LEDs in the switch of the Q8 Pro are not RGB and therefore you cannot control / change their colours.
B. The reflector is screwed on to the body of the light from the inside. You would have to remove the driver first and then remove a screw that holds the reflector in place.
Magnus.LPA
Aaand thank you Hat
Very clear answers, you did help Smile
A. Disappointed that I cannot change the color of the switch, but at least I now know why it did not operate.
B. Understood. I will do that.
Magnus.LPA
PS: this forum really is invaluable. I really appreciate it and I love the spirit of this community.
It is a pleasant hobby, that I am very happy to share with pleasant people Smile
raccoon city
raccoon city's picture
Last seen: 31 min 2 sec ago
Location: Palm Desert CA ~ West Coast is the best coast
Thanks for signing up, Magnus.LPA!
Your English is perfect although you are in France.
How many languages do you know?
Magnus.LPA
Thank you!
I was born in France and then lived in various places, so I speak:
- French
- English
- Spanish
- Italian.
raccoon city
Nice!
Although I took 2.5 years of Spanish in Junior High and High School, the only language I know well is English.  :FACEPALM:
Codec
Last seen: 3 days 22 hours ago
Performance aside, you simply cannot beat the OG Thorfire Q8.
Magnus.LPA
raccoon city wrote:
Nice!
Although I took 2.5 years of Spanish in Junior High and High School, the only language I know well is English.  alt=:" />
Well, that is enough to be understood almost worldwide Smile
Magnus.LPA
Interesting! Smile
What do you think makes the original one better than following versions?
Is it soldering quality or things like that? Is it the tighter beam pattern? Or the tint?
Codec
Magnus.LPA wrote:
Interesting! Smile
It’s the fact it’s the original version, that was designed here – and is perfect in every way.
Other versions are simply using the OG design with newer technology, and they don’t really have the status and aura of the original one.
I’m a person who likes old school, I own 2 90s cars and will always deem them better than newer cars. I suppose that ethos has rolled over to some torches I own, Q8 included.
