I have a Yezl T9 Big Head (18650) http://www.cnqualitygoods.com/goods.php?id=1107 , the Yezl is larger, has a bigger lens and projects a smaller/brighter hot spot and feels more solid (as well as being bigger/heavier) it also sells at around $27.00 plus shipping compared to $14 inc. I changed the driver in it to get rid of the strobesand get a little more output.
Most of the time I grab for a C8 or a XML P60 but this light will get some use as it is a little smaller and has a novelty factor to it.
Thanks UPz. That's quite a difference, although the SK68's bezel and lens can be easily removed so that it can be used in mule mode to flood a room. Can this also be done with the SK98?
HEY, this thing is SMALL for an 18650 light. With the lense set to "flood", it is exactly the length of an S-Mini, almost 3/4 of an inch shorter than a P1, which I consider a small 18650 light.
The headpiece has plenty of friction to keep it from getting loosy-goosey, and my light focuses fine on max throw. My only complaint is that is has a strobe mode instead of a Medium mode.
The light always starts on High, which is good since I might not have to cycle past Strobe.
Tailstands VERY nicely, good machine work, clip is functional, lots of cooling fins, and it looks to be a real Sipik.
Still daylight out, so I can't say much about the beam, but for $14 it is a nice light. It is my only zoomie at this point.
Hey Troop, please give us a report on the outdoor experiments ASAP! :bigsmile:
I'll order one this weekend if I can get your endorsement. I know it's pretty inexpensive and I shouldn't bother so much but I suppose it's more principle since these flood-to-zoom lights are sort of a hit or miss and generally lower quality. I'm just making this hard on myself :p
Thanks for the quick update. So maybe the XR-E is still better for throw in the SK98? I wasn't sure if the XM-L could possibly match it based purely off of the significantly increased power.
So how do you figure it fits in to your collection as a practical EDU (Every Day Use) type of light? Is it worth keeping at the top of your rotation? I suppose it's very similar to the SK68 but with more power.
Thank you for those beamshot. It looks like it floods in a very wide angle. That is just what I need from a work light.
Biiig flood for the up close are work. And a strong clip so I can clip it on to my ear protection. And cheap. And 18650 battery runtime. And a really low low - oh well. After driver swap it is still only 20 $ ;-)
My thoughts on zoomies in general and this Sipik98 specifically;
It is a fun light, but I don't take it seriously. If I needed an EDC, this would not be it. If I was a LEO, this would not be my daily light. Fun to play with, but the lack of a real reflector makes it a weak light in my eyes.
But it is a cool toy for 14 bucks, and I'm sure it will get a lot of attention from non-flashaholics. Way better light than the multiple LED stuff people buy at checkstands or Hardware stores, but not on par with a P1 or C8 or such. I'm just not a fan of aspherics.
I have yet to buy an SK68, so I would not be able to tell you...
LOL, funny, I just remembered that I bought 3 Citi clones of the 68, they are still in a drawer in their unopened boxes. I will check them out tonight. I think they are XM-L though, but I could be wrong.
Nope, not XM-L, the emitter-image "box" only has 2 internal lines in it.
Well, I bought this light hoping for the bet, and as others have said, you get the worst pretty much. Flood is nice, but zoomed in not very bright, my HD2010 destroys it for throw with a larger lit area and my UF-T50 is better for flood overall. For under $16 can be too mad, but even at that cheap price it definitely is not worth it, may just take it apart and salvage the XM-L and toss the rest.
