Interestingly, the SP-40A is not equipped with a head mount, or is it a typo?
0.46€ 90% OFF|8 grad TIR Optik für SP40A 19.4*8,5|Tragbare Beleuchtung Zubehör|...
Smarter Shopping, Better Living! Aliexpress.com
Hi Jackie, has the Sofirn SF11 4x AA been discontinued?
it is a typo, come with headband
yes, it has been discontinued
Hi Jackie, will there be any new updated version of Sofirn 4xAA light?
I know it’s not as popular as other lights, but I like the shape of it
Jackie: Sillen:Hi Jackie, has the Sofirn SF11 4x AA been discontinued?
Hi Jackie, will there be any new updated version of Sofirn 4xAA light? I know it’s not as popular as other lights, but I like the shape of it
seems we do not have a plan till 2022 of a 4*AA light
Q8 PRO discount price now $69, could use a code as well
So none at all left in stock anywhere? I wanted to get some for Christmas presents.
It would be nice to get some notice before products end productions so I can hoard some
Any plans for the IF22A to come with Anduril 2?
It sounds not bad
Hey Jackie.
Is it possible for me to buy the SP40A tir optic alone?
Earlier in this thread you said you would make a listing on aliexpress.
Thank you.
Hey Jackie. Is it possible for me to buy the SP40A tir optic alone? Earlier in this thread you said you would make a listing on aliexpress. Thank you.
Hi, i have updated a link, photos will update soon:
Nooner:Hey Jackie. Is it possible for me to buy the SP40A tir optic alone? Earlier in this thread you said you would make a listing on aliexpress. Thank you.
0.46€ 90% OFF|8 grad TIR Optik für SP40A 19.4*8,5|Tragbare Beleuchtung Zubehör| - AliExpress
8 degrees ?! A toss instead of a spill, or a typo again?
Jackie, would you happen to have a tool to help in unscrewing the SP40 bezel?
I have removed the bezel from an earlier SP40 (XPL-HD) before (it got a few scratches).
but when I tried to remove a newer SP40 (LH351D), I had trouble removing it (I do not want to scratch the bezel…)
Jackie, would you happen to have a tool to help in unscrewing the SP40 bezel? I have removed the bezel from an earlier SP40 (XPL-HD) before (it got a few scratches). but when I tried to remove a newer SP40 (LH351D), I had trouble removing it (I do not want to scratch the bezel…)
Try to turn on Turbo for a couple of minutes, and unscrew it by resting on slippers or a rubber mat ... I did just that, and it was with SP40 (LH351D)
Can you tell me about the PWM on this SP10V3.0? I had one of the older AA/14500 lights and the PWM was so bad that I gave it away, gave me a headache.
will check with our engineer on Monday
get a reply now : about 20khz
Pressing it into the bottom of a mouse pad or a rubber jar opener has worked well in my experience.
I started off using snap-ring pliers, and also scratched the bezel. Then I found out friction is often enough, and it made modding a lot easier.
