Will this be in the store? Green auxiliary lights is fine also
Hello. The flashlight's MCU is programmed to set 10 dimming modes. The playability is very high. The tailcap is a mechanical switch.
Yes,The background light has red, green and blue options. there is a background light option under the product link in the store.
Will DF02 be in the store?
annyli fhashlight: supreme:Will this be in the store?!https://i.ibb.co/Gv8h2tZ/1-BB97-DFC-8051-4-E8-C-9-DF0-426864172874.jpg! Green auxiliary lights is fine also
DF02 will not appear in the Amazon store, this product is only sold in the mall. Shipped from China, the U.S. receipt time 15 days -20 days. the DF02 inventory is already very small.
Is it 18650 or 14500, the description says both
Are these with xpl hi or sst20 pictures and description has both again
And What color temperature, cct?
Thanks
Is it 18650 or 14500, the description says both Are these with xpl hi or sst20 pictures and description has both again And What color temperature, cct? Thanks
Use 14500 battery
LED:3 XPL HI 5000K
Plasmatoast:Is it 18650 or 14500, the description says both Are these with xpl hi or sst20 pictures and description has both again And What color temperature, cct? Thanks
Use 14500 battery
LED:3 XPL HI 5000K
Thank you !
Ordered
annyli fhashlight: Plasmatoast:Is it 18650 or 14500, the description says both Are these with xpl hi or sst20 pictures and description has both again And What color temperature, cct? Thanks
Use 14500 battery
LED:3 XPL HI 5000KThank you !
Ordered
When you get it maybe you can post what the UI actually is, since their response was super unclear.
Nice looking flashlight, but why is the machining on the head so rough?
Is the optic something standard sourced from a 3rd party, or custom made? I’m curious to know if there are multiple options, as with Carclo (such as different blends of throw/spill).
This is the tool marks coming out of the CNC machining center.
The technician will make improvements for future production.
Thank you for your valuable comments.
Optics were purchased by a third party
Carclo is no longer able to change.
If you need SST20 other color temperatures need to be shipped from China
Receiving time 15-20 days
Use 14500 battery
LED:3 XPL HI 5000KThank you ! Ordered
Thank you We look forward to sharing your experience when you receive the goods.
It’s going to be a while before I report back. Amazon Prime had a deliver window of next Monday thru December 3.
OK Very much looking forward to it
What is wrong with the clip attachment in the first photo?
Looks like a spacer on top of the clip screws to hold it down?
Is that just an optical illusion?
What is wrong with the clip attachment in the first photo? Looks like a spacer on top of the clip screws to hold it down? Is that just an optical illusion?
The clamps are held in place by screws.
There is no spacer.
Looks like it’s the light hitting it from a different angle (note how the clip’s shape is formed from a single piece in other pics). It looks like another piece since the bend is so clean.
vonroyale:What is wrong with the clip attachment in the first photo? Looks like a spacer on top of the clip screws to hold it down? Is that just an optical illusion?
Yes. The clips are separate. Now that the video has been updated, it is clear to see
