Astrolux EC06 - some pics & a beamshot
I like the default Simple UI on the EC06, it has full power and double tap from off for Turbo!! Ramping right up to Turbo.
Toykeeper or Tom have come up trumps at last with A2. It really is good now.
I’d still like Advanced mode to ramp to turbo and double click to Turbo from off, and maybe sack Simple mode off for a INSTANT-MUGGLE mode where 6 taps sets off the flashlight automatically raising output from the floor and you tap once at a suitable level to lock the ceiling so you can quickly lend it out.
It's all TK's doing for this, adding more options. My tracking says "arriving late" and turns out to be true .
Could easily DMM probe to determine if it's FET+3 or FET+1+2. Hoping just 2 channels because 3 channels eats up valuable code space, and you would have to drop some feature like SOS to get it to fit with the new Anduril 2.
I get a bit of pressure escaping when I open the charging port cover, is this because I’m using 18650’s and the extra air volume is expanding more?
Just got mine and put fresh Molicell P42A in it. Very bright and very hot within seconds. Low settings are only slightly yellow so I did well in the tint lottery.
Ohh - looked more carefully at the driver. It looks like a FET+ 3 with it wired so each pair of LED's gets a FET+1, but driven in parallel from the MCU. I think that's what they did. Interesting way of wiring it. Clearly each FET/7135 pair is output wired independently from each other. Makes you wonder, based on % tolerances of the FET's if each pair may be brighter/dimmer than another pair. I've never seen multiple FET's wired like this - usually they just wire them in parallel, with shared output.
Dunno, maybe there's a slight advantage this way.
d_t_a - you are right, pretty sure anyway - FET+3 but uniquely wired up
If you got a Convoy 3X21A, you should try the flat top adapter in this light, see if it fits - suspect it will. Mine fits the Haikelite HK90 well.
I check our EC06 video with this turbo runtime graph
And I’ve compare to our old MF01S with this turbo graph
on the first I presume that green line is 0
After check that I reread my previous post
This 2 light have too much power if you use turbo
But we can see at our graph MF01S have possibity to evacuat heat a middle outpout and a possibility to have just a decent outpout a high temp level use
At the first run graph EC06 it’s just a falls to near near near so close 0 output :person_facepalming:
I validate myself with my hand and eye tools this light a no capability to evacuat heat so at any power output it will fall below 1000 (1000 i’m very sweet….)
Not 1000, 300 >_<
I’m ok beam is nice, so long as the light is not hot :wink:
No idea what happened for your testing, but my EC06 is getting over 22K lumens with P42A’s and my setup always measures slightly less than a calibrated Sphere.
Powerbank showing there’s enough power, but find it’s buggy as it lights up randomly in use. I believe this is made by Sofirn since the Sofirn and Wurkkos models behave the same
I had to calibrate the voltage readout as it was showing 4.4v at full charge and DMM showed 4.20
I’ll let you know what I get with P42A when my fresh ones arrive.
22K? wow, that's awesome! I assume that's at start. About 3670 lumens per LED. Maybe that triple channel of FET+1 design does work efficiently.
I see the EC01 was measured at 4200 lumens at start on a 40T, spec'd at 3500 lumens with one XHP50.2. Figure the EC06 has 1 cell, 1 driver circuit per pair of LED's while the EC01 has the same for 1 LED, so seems to make sense.
There isn't much to mod to improve output on this light - brass contact ring on the batt+ end, bypassed springs on the batt- end, 3 pairs of LED wires, etc. Might be room for heavier gauge, dunno. Doesn't say if the lens is treated or not, type of glass, etc.
It’s possible I use the two screenshot take on our vidéo to post in my personnal rewiew of this light?
Of curse give link to our video on my rewiew or I almost totally disagree but which remains very interesting
Yeah sure
I’ve just stuck 3 fresh MOLICEL P42A cells in and got 26,0000 lumens at turn on wtf!!!
Thank guy :slight_smile:
My EC06 is coming tomorrow - it arrived at my local post office, closed today. Yea, 26K is quite crazy. In my testing the Lishen's LR2170LA did as good as the original 40T's - here in US for $4 each. The new 40T's, think 40T-3, is lower performing. I can test it with various sets of 21700's using Simon's 3X21A flat top adapter - it should fit.
I have been keeping an eye on this item since it was announced. I have lots of lights in this size class, but the price point for this item is extremely attractive for the quality. Just one question before I decide if I should order a few to make gifts of:
General consensus, how many lumens at turn on with 40T? I know of the tint lottery, but do we now have a power lottery?
I don’t have a meter but mine is much brighter than the DM70. At least twice as bright as Quad XHP50.2 FT02S. I really understand where all this heat is coming from. If I only take it to the FT02S turbo level the runtime is much cooler. MOLICEL P42A used in all three.
Oh boy, this light is legit power. Just got it and been taking some pics, made a few measurements. I used fresh new Vapcell T42 cells at 4.20V, as good, maybe slightly better than the 40T's and measured 28090 at turn on! Ouch! Yes, flesh scorching hot in just a few seconds.
Measured again over 10 secs: 27755 at turn on, 25360 at 5 secs, 24660 at 10 secs. Lumens are with the maukka calib factor. My old calib factor got 12% higher lumens, so these #'s are conservative side, but make note this is not at 30 seconds.
Throw with a 2 sec pause, taken at 5 m: 127 kcd
Great results Tom. God knows what it’ll hit with 3 x 30T buttons or a 30T alternative with BT.
I deleted my review after I tried it with 21700’s! I sold it way short.
Have 2 posts here in the sales thread on it. This light is no fun, nothing to mod...
