Some pics of the Astrolux EC06, side-by-side comparison with some other flashlights:
(from left to right:)
Haikelite HK04 - Sofirn Q8 Pro - Sofirn Q8 Pro - Astrolux EC06 - Convoy 3X21A - Convoy 4X18A
top row: 3X21A (SFT40) - EC06 - HK04
bottom row: 4X18A (SBT90.2) - Q8 Pro (OP) - Q8 Pro (SMO)
Astrolux EC06 LED
Astrolux EC06 battery board, appears to have spring bypass wires pre-installed
Astrolux EC06 driver board
(is this called a FET +3 design? the regulated brightness level (on first battery insert) appears to be around 400 lumens level so probably 7135x3 or around 1 Amp )
USB-C charging appears to charge at 5v (up to around 3A max), and the powerbank function is also likewise.
Protocol detection with a USB meter indicates it uses DCP/5v protocol (no QuickCharge2/3 or PD) although C-to-C cable is supported.
Astrolux EC06 beamshot test
(opposite building is around 150 meter or 400 feet away from the flashlight)
www.youtube.com/embed/6P2lbqvdxyw
Given the strong resemblance to the Sofirn Q8 Pro, my guess is that the EC06 is another Sofirn-manufactured flashlight (as is the EC01 and EC03).
It uses the same Anduril version as the newer batch of Q8 Pro (Anduril 2, firmware version 2021-06-06 model '611')
(this firmware seems to be a Sofirn specific firmware, since it's not listed in Toykeeper's Anduril repository.
Also, the triple-click from Off (when set to Advanced mode) has the sequence: Batt-check - Temp-check - Beacon - SOS
The button switch light also functions similar to the BLF LT1v2.0 (A2 board):
- blinking blue while charging / steady blue finish charging
- steady orange when in powerbank mode
- green light: (Anduril state: Off/Low/High/Blinking)
