Interested
Interested
I wonder why they keep changing model names.
Interested , with the 26800 and battery.
Very interested!
....especially with the potential option of a 26800 battery tube and 6800maH QB26800 cell!
Interested
Interested
I second the idea of Ocelot, please include the options of an 26800 tube and a QB26800 cell, as well as an SS bezel.
Neal said he will include 26800 option soon.
Interested
Why so expensive? This can be had anytime on AliExpress for $54 and slightly more for the SS bezel, is the group buy going to be cheaper than that?
Does this mean I won't be the only one in the world with a flashlight using this LED? Dang!
In the tests I did, it's possible to hit 9300 lumens on a single very good cell. I recorded 9880 lumens on a single 30T, probably at start.
On a set of 3 Lishens in the WT90, recorded 10390 at start, 9030 at 30 secs.
On a set of T42's, should do even better.
Figure the throw will be about 1/2 in candela of what you get with a SBT90.2 - least that's how it performed in the WT90.
Yep so it will be about 40% less in distance which is still plenty. The beam should have a great quality an it should be an amazing hiking light. I found the SBT90.2 beam to be a tad too narrow for close up usage.
I’m going to pick one of these Mateminco’s on Double 12 so I might be the “second” with this Led on hand. By the way, I’ve said in the other thread that this Led is likely made by San’an Optoelectronics.
Intradested thx Freeme
How is the tint and have you measured the output of the SBT90.2 version or any other single cell 10000ish lumen lights. Would love to know how it compares to them. I also wonder how much current this thing pulls.
interested
When you say T42’s do you mean vapcell t42 ? And are they better then Samsung 30t as far as current ?
interested,
TomE -
Is there significant tint shift in the SMO reflector of the WT90 with this SFH55 LED?
When i installed my smooth reflector in the MT70 mini for the sfn55.2 the hotspot was YELLOW. didnt bother me terribly, but would be nice if this LED could be run through a Smooth reflector too.
yes please! or at least if they would do it with the SFN55.2, that would be nice too!
HI freeme,
this PD90S comes with ss bezel @ nealsgadgets?
