I had that happen on an old computer, took a long time to figure out it was the RAM because it was very intermittent.
I tell you being down to 32MB (yes MB) of RAM was no fun even way back when.
So you have my sympathies
Thanks, appreciate it. It’s probably only going to cause trouble on a browser that was already using the old version of the Advanced editor. Still not sure why Chrome wouldn’t clear the cache, but that’s the issue.
Okay, I'm on my mom's laptop.
I had to run CCleaner to be able to post on BLF using Chrome.
I did not get any errors like on my laptop, so that's good.
By the way, when I could not post on BLF, I couldn't post with Advanced Post Editor, Simple Post Editor, or Plain Text.
So Firefox is superior
Okay, I’m on my mom’s laptop.
I did not get any errors like on my laptop, so that’s good.
Had you recently used BLF on that laptop and browser?
I tell you being down to 32MB (yes MB) of RAM was no fun even way back when.So you have my sympathies
It took me a while to figure it out for me too.
My desktop computer would give me Blue Screens of Death every day or two.
I tried lots of fixes, and even tested RAM while running Windows, but I was told by Windows that my RAM was fine.
So far, Memtest86+ has done at least two passes, and has found lots of errors.
I won't know how bad it is though until I stop Memtest86+'s test, and I'm not going to do that until I get up tomorrow.
Speaking of which, it's almost my bedtime.
Yes.
Bort:I had that happen on an old computer, took a long time to figure out it was the RAM because it was very intermittent.
I won’t know how bad it is though until I stop Memtest86+’s test, and I’m not going to do that until I get up tomorrow.
Speaking of which, it’s almost my bedtime.
If i remember correctly it was a process of elimination for me but windows would BSOD spontaneously in those days anyways so that made it harder to track down.
I had an HP hand me down blow a ram chip but i forget how but i figured it out quickly.
My main rig uses a good brand of RAM so no failures in the last 8 years on it, fingers crossed.
But Windows 8.1 is dead in 2023 so i will need a new computer then.
My desktop is overclocked, so I have to use very good RAM.
I've had it almost twelve years, though I did add more RAM to it about two years ago.
I won't know which RAM sticks are bad until tomorrow.
You don't like Windows 10?
It's very similar to 8.1
And W11 is very similar to W10.
Bort:My main rig uses a good brand of RAM so no failures in the last 8 years on it, fingers crossed.
I’ve had it almost twelve years, though I did add more RAM to it about two years ago.
I won’t know which RAM sticks are bad until tomorrow.
No overclocking on my end.
Bort:But Windows 8.1 is dead in 2023 so i will need a new computer then.
You don’t like Windows 10?
It’s very similar to 8.1
Windows 11 on a 10 year old (by 2023) computer is not going to run very smoothly.
That said no previous computer of mine has lasted this long.
Windows 11 on a 10 year old (by 2023) computer is not going to run very smoothly. That said no previous computer of mine has lasted this long.
Depends on the computer's components.
My gaming desktop will be twelve or thirteen years old next year, and I'm sure that it'll run W11 just fine.
There is a workaround to install W11 on old computers, though I don't think I'll be able to get updates.
Bort:Windows 11 on a 10 year old (by 2023) computer is not going to run very smoothly. That said no previous computer of mine has lasted this long.
Depends on the computer’s components.
My gaming desktop will be twelve or thirteen years old next year, and I’m sure that it’ll run W11 just fine.
There is a workaround to install W11 on old computers, though I don’t think I’ll be able to get updates.
I have a i7 4770K, 16GB Ram and so forth. Top of the line at the time.
Its fine for now but i am noticing some slowdown running modern software.
I prefer simple and updated so i plan to upgrade the computer once the updates for Win 8.1 run out.
Test
Test
Thanks! Did it just work for you, or did you clear your browser cache? And which browser?
Advanced Post Editor not working.
Advance Post Editor is working fine. This is one of the few sites that go well with my FF.
The Advanced Post Editor didn't work for me on Chrome either.
Inspect
(If you don't see that then click the 3 dots in the very top right of Chrome and go to More tools
, Developer tools
)Network
tabDisable cache
Disable cache
and close the web inspector
Test test test
Advance editor seems to work in Chrome for me.
This is off-topic, but luckily that's usually not a problem around here.
I didn't like the UI of Memtest86+, so I used MemTest64.
I know that Memtest86 and Memtest86+ are better programs, but I got good results from MemTest64.
My problem is with one stick of RAM, but I'm not sure which one.
I'll have to remove one or two sticks of RAM (out of 4) at a time and re-run MemTest64 to narrow it down.
My advanced post editor is working now. Have to wait for couple of minutes to come into effect after clearing my browser cache.
