Yes.
If i remember correctly it was a process of elimination for me but windows would BSOD spontaneously in those days anyways so that made it harder to track down.
I had an HP hand me down blow a ram chip but i forget how but i figured it out quickly.
My main rig uses a good brand of RAM so no failures in the last 8 years on it, fingers crossed.
But Windows 8.1 is dead in 2023 so i will need a new computer then.
My desktop is overclocked, so I have to use very good RAM.
I've had it almost twelve years, though I did add more RAM to it about two years ago.
I won't know which RAM sticks are bad until tomorrow.
You don't like Windows 10?
It's very similar to 8.1
And W11 is very similar to W10.
Bort:My main rig uses a good brand of RAM so no failures in the last 8 years on it, fingers crossed.
I’ve had it almost twelve years, though I did add more RAM to it about two years ago.
I won’t know which RAM sticks are bad until tomorrow.
No overclocking on my end.
Bort:But Windows 8.1 is dead in 2023 so i will need a new computer then.
You don’t like Windows 10?
It’s very similar to 8.1
Windows 11 on a 10 year old (by 2023) computer is not going to run very smoothly.
That said no previous computer of mine has lasted this long.
Windows 11 on a 10 year old (by 2023) computer is not going to run very smoothly. That said no previous computer of mine has lasted this long.
Depends on the computer's components.
My gaming desktop will be twelve or thirteen years old next year, and I'm sure that it'll run W11 just fine.
There is a workaround to install W11 on old computers, though I don't think I'll be able to get updates.
Bort:Windows 11 on a 10 year old (by 2023) computer is not going to run very smoothly. That said no previous computer of mine has lasted this long.
Depends on the computer’s components.
My gaming desktop will be twelve or thirteen years old next year, and I’m sure that it’ll run W11 just fine.
There is a workaround to install W11 on old computers, though I don’t think I’ll be able to get updates.
I have a i7 4770K, 16GB Ram and so forth. Top of the line at the time.
Its fine for now but i am noticing some slowdown running modern software.
I prefer simple and updated so i plan to upgrade the computer once the updates for Win 8.1 run out.
Test
Test
Thanks! Did it just work for you, or did you clear your browser cache? And which browser?
Advanced Post Editor not working.
Advance Post Editor is working fine. This is one of the few sites that go well with my FF.
The Advanced Post Editor didn't work for me on Chrome either.
How I fixed it:
- Right click anywhere on the page, click on
Inspect
(If you don't see that then click the 3 dots in the very top right of Chrome and go toMore tools
,Developer tools
) - Go to the
Network
tab - Check
Disable cache
- Reload the page
- Go to the Advanced Post Editor and check it works
- Un-check
Disable cache
and close the web inspector
Test test test
Advance editor seems to work in Chrome for me.
This is off-topic, but luckily that's usually not a problem around here.
I didn't like the UI of Memtest86+, so I used MemTest64.
I know that Memtest86 and Memtest86+ are better programs, but I got good results from MemTest64.
My problem is with one stick of RAM, but I'm not sure which one.
I'll have to remove one or two sticks of RAM (out of 4) at a time and re-run MemTest64 to narrow it down.
My advanced post editor is working now. Have to wait for couple of minutes to come into effect after clearing my browser cache.
...and the mystery is solved!
I had 2GB + 2GB + 4GB + 4GB of RAM.
One of the 4GB is bad (and I know which one).
That surprised me because that RAM is way newer.
It has excellent feedback on Amazon, too.
So, now all I have to do is buy and install more RAM, which is no big deal.
I can get away with only 8GB, like I am right now, but I'd rather have 12GB.
EDIT:
Hmm...
The RAM that went bad has a lifetime warranty.
I think I'll be contacting Kingston to get my RAM replaced.
…and the mystery is solved!
I can get away with only 8GB, like I am right now, but I’d rather have 12GB.
EDIT:
Hmm…
I think I’ll be contacting Kingston to get my RAM replaced.
My first question is always warranty so glad you got that covered :+1:
I just ordered a ten pack of antistatic bags.
(I only need one right now, but I might need some more later, and they're cheap.)
Once I receive them, I'll see if Kingston will honor their warranty.
Sorry for the hassle freeme, I assume this was also with Chrome?
Yup, Version 96.0.4664.110.
freeme:My advanced post editor is working now. Have to wait for couple of minutes to come into effect after clearing my browser cache.
This is off-topic, but luckily that’s usually not a problem around here.
Actually I appreciate you keeping this thread going to keep it visible, just in case there are other users with an old cached version of the Advanced Post Editor that think it’s not possible to post.
