I will wait for a review before ordering.
Thx anyway.
MCA - Olight Store
MCA, Direct plug-in, class 2 magnetic charger; compatible with Obulb Series, Baton 3, Perun Mini, S2R Baton II, S2R Baton, S1R Baton II, S1R Baton, H1R.
Price: $ 14.95
Thx anyway.
Looking forward for your review Liitokala Li600 review HKJ
Hi HKJ, are there any new information/plans on your review of the Liitokala Lii600?
HKJ, have you ever reviewed any of these budget wall charger brands? (even if not exact model, would be good to know if any are sketchy or good brands in general)
- Elecife
- Choetech
- Ugreen - i think this one is generally a good brand and have seen some reviews of other models from them by you that said they were OK/Good (but not great)
hiii HKJ, any updates on Lii-S6 ?
Please if someday you want, review the Lii-600
Thanks in advance!
Hello HKJ,
really appreciate all the reviews you do on batteries (especially NiMH) and chargers, they’re great and really thorough!
I’d like to propose the IKEA STENKOL charger for review.
From description it appears to have two current sources (8hrs for 4 batteries, 4hrs for 2) and each slot is terminated individually.
Its main termination method seems to be 0dV/dt, with -dV/dt, temperature and timer for backup termination.
Also it claims to terminate on a full charge, so they may have left out trickle charge, which would be good for LSD cells as you know.
Another feature it claims to have is “rejection of defective cells”, which could mean minimum battery voltage or maximum internal resistance.
Especially internal resistance limit would be interesting to test since this would limit how often the laddas they sell can be recharged. This data could be guesstimated from AAcycler’s data.
I think for such a cheap and easy to use charger, it’s fairly interesting even for us who care about our NiMH cells, so it might be worth a review!
Kind regards,
def_nvar
Suggestion for review (thank you very much in advance):
Astrolux VC04
https://budgetlightforum.com/t/-/63856
Here’s the fixed link:
banggood.com/Astrolux-VC04-Micro-Type-C-2A-Quick-Charge-Li-ion-Ni-MH-Battery-Charger-Current-Optional-USB-Charger-For-18650-26650-21700-AA-AAA-Battery-p-1752461.html
[S\$280.78 30% OFF]NOKOSER TC-X-Pro Smart Battery Charger 6-Slot Auto-Polarity Detect for 26650 21700 18650 14500 20700 16340 A AA AAA Flashlight from Lights & Lighting on banggood
https://banggood.app.link/UeLzRz4aGib
New charger. Seems cool but the price is crazy
https://banggood.app.link/UeLzRz4aGibNew charger. Seems cool but the price is crazy
Look to be the same as
https://www.amazon.com/EBL-Universal-Discharge-Functions-Rechargeable/dp/B09B9HFXJ7
I’d like to suggest the LiitoKala Lii-S8 for a review:
banggood.com/LiitoKala-Lii-S8-8-Slots-LCD-Display-9V-Quick-Charger-Smart-Battery-Charger-for-Li-ion-LiFePO4-Ni-MH-Ni-Cd-9V-21700-20700-26650-18650-RCR123-18700-p-1780562.html
I’ve urged Olight (on their FB thread) to send one of these to HJK:
Price: $ 14.95
It’s a magnetic charger for their proprietary batteries that have both + and - contacts on the same end
same as EBL TC-X Pro Amazon.com for $119
Or Epoch X4 Touch on sale right now for $89 at Epoch X4 Touch - LCD Touch Screen 4 Bay Battery Charger?
negatives
positives
no idea who the OEM is, if it is EBL or someone else. not from one of the major charger companies (skyrc, xtar, nitecore,vapcell, efest) so i’d be concerned of their learning curve.
So not a charger but something that could make a charger more effective. Here’s an article about an active cable that acts as a PD bridge of some sort and seems to be able to take a PPS capable power brick and find a better protocol match than a dumb cable with a device to be charged when the two are not from the same manufacturer.
今天,聊点不一样的东西。 C2C快充线是USB-CtoUSB-C快充线的简称,也是目前市面上普遍流行的快充线类型,它拥有接口体积小,支持功率高,支持正
Thoughts?
It is hiding the phones preferred charging selection and would likely result in damage to the phone
HKJ, you had done a Fenix ARE-D1 in the past. There are two others I think may be worth looking at. There’s the ARE-D2 and ARE-A2. The D2 looks more interesting, as it has a current range from 0.5A to 2A (the A2 is limited to 1A). Of course, that means no safe 10440 support, despite Fenix claiming 10440. I had communicated with their CS by email and they confirmed—the ARE-D2 will not go below 0.5A.
Would love to see this spigen travel charger reviewed:
Why? It’s the lightest 2-port GAN/PD charger I know of at 2.5oz that I’d like to use for backpacking, but not sure if I can trust Spigen vs an Anker 521 equivalent.
I´m not sure whether HKJ is still active
