Charles BridgTec has a review on this light, released today!
I will say that I am pleasantly surprised with the flashlight, as far as I can tell
Thanks for the opportunity. You have come up with a very interesting brand name.
There’s no magnet in the tail. You could probably fit one in under the spring but the protected 18650 may fit tightly. The head also has a spring. An unprotected flat top may work well with a magnet under the spring.
ED10 reflector is about 15% bigger than the SC31 Pro reflector.
ED10 has OP while SC31 Pro has SMO reflector.
ED10 is slightly shorter than an SC31 Pro with a non-magnetic tailcap.
ED10 is slightly wider than an SC31 Pro.
ED10 charge cover sits flush with the head while the charge cover in an SC31 Pro sticks out. SC31 Pro cover feels more durable.
ED10 tailcap is smooth while SC31 Pro tailcap without a magnet has a sharp edge (lanyard hole).
ED10 metal button feels nicer IMO compared to the rubber switch cover in the SC31 Pro.
ED10 knurling looks nice but the more aggressive knurling on the SC31 Pro may be more practical in terms of providing grip.
I’ll try to remove the driver after I’ve done runtime tests.
Thanks for this GAW!
Welcome abroad! Unique name and thank you for the giveaway.
Welcome @Lezer and thanks for the GAW!
Nice looking compact and stylish design.
A tooltip on the website indicates SST40 6500K which is not going to be a favorite here. +10 for warmer CCT / high CRI!
Welcome VezerLezer.
I like the UI. Looks well thought out. I assume there’s last mode memory from one click on?
Good looking flashlight with decent UI.
I too would like to know what “Ramp Style Swap” means.
I’m in!
Seems nice, looks like sst40? Any plan to offer other emitters?
Nice entry and welcome. Looks like a good work light.
Count me in and cheers
good looking flashlight. thanks for the gaw.
mos+7135
Hello,
It looks nice and compact for the power offered. I also like the UCB-C charging possibility very much.
I will check for your products from now on.
Nicely done.
The UI looks fantastic, what I’d want from a non Anduril light.
‘Ramp style swap’. Is this stepped and smooth ramp? It sounds familiar
The construction also looks familiar like sofirn SC31 but it’s different enough not to be a clone. angular pattern makes its stand out.
Any relation to sofirn?
Also does this have C to C charging? I’ve notice reports that some brands use charging chips that don’t support that.
Amazing Light, expecting more models to come.....
HCRI 4000K-5000K please.
Nice UI/modes. Looking forward to a review one day.
