Maybe a soldering iron tip would loosen the glue? Is there any gap where a good thin spring steel hook/pick could fit…like the thin dental pick types but good quality.
Okay, this is a NCR 21700T which seems to be from Tesla.
There was a black sticker over the plate with holes to remove it. Not so good news is that it’s spot welder with wires, there’s no rear spring. I have a spot welder, so no issue for me, but everyone else won’t be able to replace it, should they ever need to.
I haven’t, no, nor do I want to see anymore of anything sheep related lol I’m surrounded by them.
I’ll try get the footage and better beamshots tonight and get this review done.
Pulled the whole driver out and cell. The cell is attached with a plug connector.
Thought I wrecked it since reconnecting the cell it didn’t work, I had to hold the switch down for awhile until the switch flashed red…PHEW
Pictures to come.
After watching this film, I think I understand you 100% there.
Here’s the shimmer on Low with the front lens removed. It’s not a battery connection issue, must be the driver
I’m tempted, but non removable battery makes it a hard sell. Also no lockout is a big negative too.
Watching with interest.
Yes, no lockout is an issue. It’s not an easy to press switch that sticks out, so not massive problem.
Battery can be replaced if you know what you’re doing. If someone doesn’t have a spot welder, then just carefully solder.
A local Batteries Plus store once graciously spot welded tabs on a nihm cell for me. They were quite kind and offered without my having to beg.
That’s a sticker?!
I mean, I have the light right here in front of me - would NEVER have thought there was a sticker on the back. Perfectly applied i must say.
THANKS A LOT for taking it apart! Now I know exactly what to do, should I ever need it. :+1:
P.S. Regarding the replacement cells, if you’re EU based, NKON f.e. sells cells with tags already soldered on.
I heated it with my heat gun and it bubbled up over those two hole inserts, so glad it’s not too hard to dismantle.
Also did some candela measurements:
Confirming the readings of Funtastic - peak of my measurement was 534k cd, at 10m distance.
(Wainlight C8+ with Osram W1 clocked in at 107k cd, same setup, so maybe it’s also a little bit on the high side)
Playing with my camera’s exposure, looks wicked lol. Just finished all my footage for my upcoming review
I got my SF2 in a week and half ago. Tested it on Medium and Low and I did get the shimmer you mentioned. It’s not as visible as yours though, and it’s not like PWM, but it is there. It does not do this on High mode. Not sure what it is? I don’t want to take it apart though.
My numbers are similar to yours!
Hmmm, well they’re sending me a replacement so I’ll be able to confirm whether it’s a fault on yours or it’s normal. They offered $5 usd per sale or a replacement once I reached $75, but they then offered one at only $25 in sales, so I grabbed it.
I don’t think there is any PWM, at least not visible with my camera up to 1/2000 shutter speed. My Armytek Wizard C2 Pro Nichia is visible at just 1/100.
Does the UI have last mode memory, and is the strobe constant frequency?
Yes to both.
Click: On
Click: Cycle high, med. low, strobe, sos, off
Hold: Off with memory
Group 2 is high only
Thanks. So a reasonably good UI for people who like strobes!
