Your RD5015 has been working well for me, as well as your USB monitors and testers.
As such, I do not have a need for more of them.
Personally, I’d love to have a high power USB monitor from you since they are very high quality, with stuff for support like ultrafast charging since I want to do some USB tests, like I have done in reviews using your products in the past.
thank you so much for your support , if you don’t more needs, it is ok, just help me to spread our products to let more people to know that
thank you again
Quick question, is there any difference between the 800W and 1000W PSU when it comes to high-frequency noise and (temperature controlled) fan speeds?
Also concerning the RD60xxP series. Is there are way to have USB from the backside? They have USB on the front, but maybe it’s possible to plug in a USB board instead of the Wifi board? And build a USB connector in the back of the case.
hello, 800W PSU may have high frequency noise when there is no load connected, it will dispear when there is load, 1000W PSU has no high frequency noise, it only has fan working noise
for the USB port, because the converter is used to inserted into a case, so only the front panel is available, so it is to meet the most customers request
as mentioned many times, when you choose input PSU for our power supplies like RD6024 and RD6018, please choose PSU which has stable DC output, we already add input voltage protection board on our latest RD power supplies, but it is better to choose PSU with stable output https://rdtech.aliexpress.com/store/1100599049
RK6006 Power Supply connection
hello, if you find device does not work normally, and you do not know what happen, just show us how you use the product, then we can find the problem, just like this RK6006 Problem, input voltage connects to output terminals, then it cannot work, but the device have protection,just connect it correctly and it can work again
