Make a poll that appears in the side bar. I’m not sure how but BlueSwordM seems to know how.
Haven’t tried it, will see how to post
single color aux leds, tried 7 colors, which better?
6 colors, ops, My math was taught by a history teacher ,lol Facepalm
Someone stole my FWAA so this is just what I need for a change.
I still want a RGB aux please
not have enough space for RGB LEDs, have a planning for a larger model such as 21700 version
AA support is very important to me. Option 2. If it doesn’t have AA support, then it should have a usb-c charging port.
…My math was taught by a history teacher ,lol Facepalm
Thats funny, I’ve never heard that one!
I like the yellow and cyan the best.
I’m glad to see these coming together.
What type of main LEDS are you planning on using? Did I miss that info anywhere?
Cyan is my preferred aux colour if there can be only one.
Is the body going to be available in colors other than black and if so what colors? And will the aux be dimmable? Those will help us decide, thank you!
Cyan colour looks great…
I think it is pointless to enter the market with a FWAA copycat flashlight.
It needs to be better than FWAA, or cheaper. Pick one - better or cheaper. Then make sure to achieve it.
Is the button better? Is the driver better?
It’s not Lumintop, that’s enough justification imho. I own flashlights of both brands and definitely have a preference (non technical/design reasons). But I do hope this one gets a decent driver, that would be an big improvement.
one should be purple, but in photo looks like a blue
that is a tape on the green light
My vote is PURPLE!
2nd is yellow….
3rd orange…
auxlight needs to have minimum drain; so the most efficient is the one that should be used.
I'll take a purple and an ice blue and a red!
keep it short
use a side switch or short tail switch like FW3A
do use anduril 2, or at least have it as an option
no magnets
no charging
under $40
Indeed. Under $40 for sure. Under $30 would be wonderful…
Option 3 IMO. I would definitely pay a little more to have anduril and good CRI/temperature. I also don’t really think it needs an integrated charger but I will say please make sure it has a good button. I have an FW1A that is totally useless because the button is so bad. It worked for about 3 days and then completely stopped working unless I press the button really hard and even then its only like 50/50 on if it registers a press.
The first post suggested $15.99 might be achievable for price. That sounds like a challenging price to achieve, but if it is anywhere close to that price, it will be significantly cheaper than the FWAA.
I did not see the driver architecture mentioned. The FWAA driver has 1x7135 chip + a FET channel, which seems reasonable for the size of the light. If there was any question about including the 7135 channel or keeping the cost lower, I would say the 7135 channel should be a very modest cost that is well worth the regulation and slightly better efficiency it enables at lower levels, compared to a light that runs only on a FET channel.
Purple!
