Bit of a late reply, but yes the HL3A has also been downgraded. I bought one a few months ago and it has the FET+1 driver. I really wish the Lume1 drivers had the ability to be used in the HL3A and EDC18, let alone be available to buy anymore!
it would be better if they just stopped produce the lights instead they downgraded them so badly… now they just make the lights look terrible vs how the orginal is…
I wonder if they degraded everything, including the Titanium and Copper/Brass versions. I would be super pissed if I spent 100 bucks on a Ti version and got the degraded driver and crappy optic.
Lumintop are shooting themselves in the foot because I have no confidence to buy ANY Lumintop product. If they want to change the specs of product for the worse they need to use a new SKU and product name so everyone knows it is different.
Have to agree, downgrading existing products makes me extremely reluctant to buy any of their new products. If only there was a good FW1A alternative (i.e. Anduril, Tail Switch, Head Diameter <28mm).
I never wrapped my head around the drivers and their components so what exactly does the new fw3a with no chips on the bottom of the driver do less than my fw3a with the purple pcb and 6 chips? I assume it has to do with power delivery from battery to emitter
Your FW3A actually has eight of those chips (two are on the other side of the driver). Each one is a 350mA current regulator. The driver uses three channels. First one uses one chip, second uses all eight, and the third uses a MOSFET (direct drive). As you increase the brightness above what each channel can deliver, it will switch to the next channel (intermediate brightnesses use PWM for dimming). Using one chip allows for lower minimum brightness and (slightly) more efficient operation at lower currents.
The bigger issue is that the firmware is not written for one or two channel drivers so there may be odd behavior when ramping with the newer revs.
awesome I just played around with the light and I can tell there is 3 different sections indicated by the bumps when ramping! makes sense to me now so the newer light just has worse ramping not as smooth but on the high end it is still the same brightness because it is just direct drive from the cell
should be good i have the 3000k nichia and beam is wonderful floody, i would get it just because if has the original driver and if u dont like the tint u can always wap the emitters if u know how do that.
