You mean allways strobo in the modi ?
Is there mode memory? And is that a forward clicky for momentary on?
I have the Mateminco branded version of this light. It’s great.
The UI is fairly simple and it has a reverse clicky switch. It always starts on low, a tap from on will go to high, and that tap can be immediately after turn on if you want to get to high quickly. A double tap from on will go to strobe, which I wish wasn’t present.
I swapped a forward clicky into mine because it’s just better. I highly recommend that. A quick double tap from off now goes to high, and it’s momentary too which is nice. I almost never run into strobe with this setup and it works great. I also swapped in a black switch boot from an SC31T because the stock salmon colored boot is kind of ugly.
I highly recommend picking one up. This is my first LEP purchase and I’m not disappointed. Thanks freeme!
Thanks for the reply. But I’ll pass. Not having mode memory immediately turned me off. Maybe if it always turned on in high , I may think about it.
Oh well, I already have a Thor 1 & 2 to play with. And the much bigger acebeam w30
All replied.
Hi Freeme,
Can I have a code please?
All replied.
Could I get a code please?
Shared.
Ordered, thanks.
May I get a code please?
Ordered, received, and I pretty much love it. Kinda hard not to if you like throwers. Thanks Freeme.
It is one of my favorite as well. 18650 is perfect EDC size for LEP in my opinion.
Can I get a code please?
Would love a code too. Thank you!
Shared.
Hi freeme can i get a code please
Can I please get a code?
Ordered, thank you! Looking forward to it.
