Astrolux® WP4 1303M 310LM Super Throw EDC LEP Flashlight
Material
Aluminum alloy, hard anodized surface
Light source
Special CT1 LEP module
Distance
1303 Meters
Intensity
425,000CD
UI
Low- High -Strobe
Lumens
310lm
Driver
Boosting Costant Current Driver
Lens
PMMA
Battery
1x 18350 or 1x 18650 li-ion rechargeable battery (18650 is included, 18350 is not Included)
Impact Resistence
2m
Waterproof
IPX6
Switch
tail press
DIY
1* Glow ring (Included, installed)
16* 1.5*6mm glow tubes (Not included)
Size (±0.5mm)
with 18350 tube: 99*32*26mm (Length x Head dia. x Body dia.)
with 18650 tube: 129*32*26mm(Length x Head dia. x Body dia.)
Features:
High efficiency constant current drive circuit
Temperature control protection: when the flashlight temperature is too high, the flashlight will automatically reduce the brightness to prevent overheating
Low voltage prompt function
DIY Glow ring
DIY Glow tube strip
Operation:
Action
OFF NOW
ON NOW
Singe click
On
Off
1 Tap
Low - High - Strobe
2 Taps
Strobe
Package included:
1 x Astrolux® WP4 LEP Flashlight with 18650 body tube
1 x 18350 battery tube
1 x Astrolux 18650 battery (Free gift)
1 x Glow ring (Free gift, installed)
2 x Spare waterproof O-rings
I have the Mateminco branded version of this light. It’s great.
The UI is fairly simple and it has a reverse clicky switch. It always starts on low, a tap from on will go to high, and that tap can be immediately after turn on if you want to get to high quickly. A double tap from on will go to strobe, which I wish wasn’t present.
I swapped a forward clicky into mine because it’s just better. I highly recommend that. A quick double tap from off now goes to high, and it’s momentary too which is nice. I almost never run into strobe with this setup and it works great. I also swapped in a black switch boot from an SC31T because the stock salmon colored boot is kind of ugly.
I highly recommend picking one up. This is my first LEP purchase and I’m not disappointed. Thanks freeme!
Thanks for the reply. But I’ll pass. Not having mode memory immediately turned me off. Maybe if it always turned on in high , I may think about it.
Oh well, I already have a Thor 1 & 2 to play with. And the much bigger acebeam w30
