MascaratumB
I did a quick search and didn’t see where they are offering discount code I am interested in 2-3 I wish they would have done it with type c charging port
That would be really nice. Actually a different switch setup altogether, but if space isn’t an insurmountable concern then adding the light would be great and bring it in line with most other Anduril lights. I don’t know if it was a practical consideration or just trying to keep the price of the light at a certain point. Just a few small improvements/fixes would make this a real standout light among many competitors even if the cost went up a few bucks.
When you are in Sofirn website, you have a banner on top (if you are a new user) indicating a 10% discount and the code.
If you select other items (drivers, flashlights), you have a smaller banner in the product page offering a XX% discount. Click on “GET” and you’ll get it on the final value.
Ive seen reports of VERY Pink sm573 dedomes, like –0.0080, even –0.0100. My experience with one sm573 dedome, is a duv of –0.0042.
What is the DUV of your dedomed sm573?
anyone else that has a dedomed sm573, and an Opple or other meter, Please share info. Please no Bare LED data… Im only asking for data in a light with its lens installed.
I initially swapped the LED to an SST20 2700k. After a while my eyes told me the DUV was too high and I tried a 219b 3k. Turbo makes it go angry blue so I switched back to the SST20. I guess I need to try a 519a.
That’s a good question. Perhaps someone more versed in electronics than me can check if there is a sense resistor. And if so, what to replace it with for more power.
Not much you can do for NiMH, it’s already maxed out.
The FET channel will run at direct drive AFAIK. You could try using thicker cables to the MCPCB and bypassing the tail spring. Next limiting factor will be the FET.
