When you are in Sofirn website, you have a banner on top (if you are a new user) indicating a 10% discount and the code.
If you select other items (drivers, flashlights), you have a smaller banner in the product page offering a XX% discount. Click on “GET” and you’ll get it on the final value.
Ive seen reports of VERY Pink sm573 dedomes, like –0.0080, even –0.0100. My experience with one sm573 dedome, is a duv of –0.0042.
What is the DUV of your dedomed sm573?
anyone else that has a dedomed sm573, and an Opple or other meter, Please share info. Please no Bare LED data… Im only asking for data in a light with its lens installed.
I initially swapped the LED to an SST20 2700k. After a while my eyes told me the DUV was too high and I tried a 219b 3k. Turbo makes it go angry blue so I switched back to the SST20. I guess I need to try a 519a.
That’s a good question. Perhaps someone more versed in electronics than me can check if there is a sense resistor. And if so, what to replace it with for more power.
Not much you can do for NiMH, it’s already maxed out.
The FET channel will run at direct drive AFAIK. You could try using thicker cables to the MCPCB and bypassing the tail spring. Next limiting factor will be the FET.
Ramping wasn’t butter smooth anymore. Pretty rough actually. but i did a rest, and it a perfect light again. Accept it still needs a 5000k 519a transplant.
