Sorry, I also keep urging and hope to receive all 519As soon
Simon, I’m wanting to build a small 450nm royal blue light and I think the T3 host and driver (complete light of course) will be perfect. Does the T3 use the same cut shape mcpcb as the T2? If so, could I buy a couple of spare mcpcb from you on that order?
Thank you for the update Simon!
Oh, the FC40 inside of Convoy lights is “only” R9050.
That does put sort of a different spin, interesting.
Maukka tested an early sample here (very green and R9 goes down to 42 on high)
Edit : zeroair tested a production sample here (much less green and higher R9, 76 kn high and above 80 in other modes)
yes, the same
if you just need 2pcs ,pls note “add 2pcs MCPCB for T3 ” in the remarks.
i will add 2pcs for free
Correllux:Simon, I’m wanting to build a small 450nm royal blue light and I think the T3 host and driver (complete light of course) will be perfect. Does the T3 use the same cut shape mcpcb as the T2? If so, could I buy a couple of spare mcpcb from you on that order?
yes, the same
Thank you, sir!
2022/5/24
519A 5700K 5000K 4500K 4000K 3500K 3000K available now
2700K will be available in one week
Long waited, and yes, we have it now… :+1:
2022/5/24
2022/5/24
Wonderful news, I’ve just put my order in and left a note for you!
Thank you!
How do the smXX5 bins compare with the smXX3 for the 519a? Do most of the neutral ones get picked out to fill the smXX3 bins, leaving mostly “extreme” green and red ones in the smXX5?
From the 5 samples I had there wasn’t much difference regarding duv, for the CCT they were a bit warmer :
2022/5/24
Excellent news. Will put in an order when 2700k arrives!
Simon, can you apply the option of 519a 5000k on T2.
Hi Simon,
Do you have any plans to make M1 host with different anodization colour options?
How do I order the 519a as LEDs?
Hi Simon,
The M1 model will be phased out.
M21B becomes popular
you can order it and note “519A 5000K” in the remarks
