I haven’t kept up with Anduril firmware for all the various lights. Hence the if so part of my post.
Since it doesn’t seem to be Anduril 2, we will have to wait for someone to compile one. At least we know anduril.2021-08-31.sofirn-sp36-t1616.hex can be used to create an Anduril 2 firmware since Sofirn seemed to use their own version for this light
I think what SammysHP is trying to say is that Sofirn should be using anduril.2021-12-13.sofirn-sp36-t1616.hex since that is the latest official build of Anduril 2 that will work
gChart, any chance that you could design a Programming Key for the SC21 Pro? If I understand correctly, it only needs three pins, but the key has to be five pins wide: (GND) (VCC) (blank) (blank) (UPDI). Too bad Sofirn didn’t put them together so that your UPDI key could be used.
Look at post #207. I improperly erased the MCU and that was causing some odd issues. The latest Anduril 2 build works great after I did a factory reset.
Haven’t kept track of changes, but are there any fixes/additions that apply to the SC21 when using a newer version? If not it won’t matter using an older version.
Don’t recall if this was mentioned earlier; the TIRs Convoy/Simon sell for the S2+ also fit wonderfully in the SC21 without the glass lens and emitter gasket just as they do in the S2+. The head will screw down more for those who don’t need the warning label to line up
I grabbed a random beaded TIR from my stash, probably a 15deg, and honestly wish this were an option from factory, it’s great.
New flashaholic here. I’m new to this hobby. I started out with a Nebo Torchy (wich is dangerous when you tend to walk around with ferrous metal shavings in your pockets), advanced to the SC21 5000k and just added a SC21 pro to the collection.
I flashed my light with anduril.2021-12-13.sofirn-sp36-t1616 according to Adair21s instructions. I soldered to the pads and used an FTDI breakout board, two resistors and a diode on a bread board for the flashing.
At first I had slow ramping. After a factory reset it started ramping normally.
Fiddeling with my light, I found out that the bezel isn’t glued (seems like they have skipped the glue on the green versions.)
That led me to order some TIR lenses from Convoy to do some experimenting.
At the same time I ordered an 2700k S2+ LH351D (I also have a 4000k SP36 BLF incoming). Into the rabbit hole I go.
Thanks. The automatic lockout was definitely worth the effort.
raccoon city:
Like Yngwie Malmsteen is the closest pronunciation for english speakers. I belive I read once that he changed from Yngve to Yngwie because no one could pronounce Yngve.
I know the D4v2 has different flashing pads. I have been able to flash the D4v2 with Hank’s adapter by simply using a steady hand and holding the pins down on the flashing pads.
Can I build a similar adapter and hold it down on the flashing pads? If so, any guide on how to build an adapter for this light? I wonder what Sofirn uses to flash firmware
